Resistor on Shunt Regulator PC Board
Aural Robert · 4883
Offline Aural Robert
on: February 02, 2014, 08:17:15 AM
I'm finally getting back to my assembly and I have a question about one of the resistors I received. On Page 26 of the manual, the top step is installing a 330K5% into the A side of R2 - it's a black cylinder with writing on it.
The resistors I got in my kit are brown dumbell shaped ones, and they clock in around 290K. I think the colors are orange, orange, white, gold. Is this the right resistor? I can't see anywhere else in the manual where the brown resistor I have belongs.
Thanks in advance.
Aural Robert.
Origin Live Calypso TT w String Theory arm & Shure V15VxMR, Eros or BH DAC -> BeePre -> MonAmor 2A3s w JJ's => Blumestein Bamboo Tritons on Blumenstein Bamboo stands, AND Enhanced SEX w Sexy spkrs and subs in the WAF zone. DIY Belden 89259 w Eichmann interconnects throughout
Reply #1 on: February 02, 2014, 10:44:42 AM
Orange, orange, yellow, gold is a 330K/5% resistor.
4-band color codes
Reply #2 on: February 02, 2014, 11:58:12 AM
If you hold both ends of the resistor onto the meter leads, then the resistance of your body is in parallel with the resistor. I speculate that's what you did, which is why you got a resistance smaller than what it should be.
Yes I do this all the time, and have wonder "what the heck?!" before I remember this caution.
Offline STURMJ
Reply #3 on: February 02, 2014, 07:34:05 PM
Parallel resistance is one of those things that I understand, But have no clue why.  It seems so counter intuitive that two parallel loads results in a load lower than either load.  It seems that the explanation for this is going to be way above my understanding of electronics,  so I just accept it as it is.
Reply #4 on: February 03, 2014, 06:43:00 AM
Imagine you have a 5 lane freeway, and next to that 5 lane freeway, you have a gravel road.
When you allow cars to drive through them both (this is analogous to current), more cars will be able to get through on both the gravel road and the 5 lane freeway than just the 5 lane freeway.  (Though the gravel road doesn't do all that much)
In the resistance model, your body is high resistance (gravel road), and the resistor is the 5 lane freeway.
Reply #5 on: February 03, 2014, 05:59:15 PM
Ah! I get that - you just have to remember that a lower resistance is not a lower load.
The inverse of resistance is called conductance, and a parallel resistor increases conductance, demanding more current, and is thus a heavier load.
Offline STURMJ
Reply #6 on: February 05, 2014, 05:14:23 AM
Ahhh now I get it. Thanks
