Background Hum - Worsens w/ volume + present without input.
Acclaim · 7699
Reply #15 on: February 07, 2014, 01:32:43 PM
The Crack is fine.  Your problem is before the Crack in your source or the interconnects.
« Last Edit: March 31, 2014, 03:26:48 AM by Grainger49 »
Offline Acclaim
Reply #16 on: February 07, 2014, 01:45:29 PM
I gotta say, the participation of these forums is fantastic. I definitely did not expect Doc B., PB and Grainger49 responding on my run-of-the-mill thread.
The thing is Grainger, there is no source or interconnects plugged in during my testing. Simply power in and TRS out.
Maybe I'll just hafta live with it.
Reply #17 on: February 07, 2014, 01:48:23 PM
What kind of headphones does Kris use with his Crack?
If shorting the inputs produces silence, installing shielded cables from the RCA jacks to the volume pot is unlikely to be helpful.
Also, what sources are you using?  How are they cabled?
It's quite often that we find folks using unshielded interconnects and/or noisy sources which present the noise problems themselves.
Reply #18 on: February 07, 2014, 01:49:32 PM
Yeah, as we keep saying - this is a meaningless test.
Offline Acclaim
Reply #19 on: February 07, 2014, 02:16:44 PM
The only reason I did that test was recognize that the hum is intrinsic to the Crack itself. During testing with a source at half-volume (loud but my ears aren't bleeding) I am able to hear the same hum between tracks.
It's not that bad and if, outside of changing my setup to whatever Kris is using, there is nothing to be done I will just move on and enjoy.
Thanks for all of the help.
Reply #20 on: February 07, 2014, 02:38:43 PM
If you short the inputs and it is silent this says that the Crack is silent.
« Last Edit: March 31, 2014, 03:26:29 AM by Grainger49 »
Reply #21 on: February 07, 2014, 02:48:57 PM
The next step would be to describe your cabling and your source, as the hum is coming from one or both.
Offline Kris
Reply #22 on: February 07, 2014, 03:19:01 PM
FWIW I also use HD650 with my crack (no speedball yet).
With test that Doc recommended, you've just proven that your crack is dead silent also and the source of the hum is outside of your amp.
Kris
« Last Edit: February 07, 2014, 03:21:43 PM by Kris »
Offline Mike B
Reply #23 on: February 07, 2014, 03:23:52 PM
This is absolutely noise free.
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Ffarm4.staticflickr.com%2F3804%2F9666763480_daff72be30_o.jpg&hash=265c97406f448a1a0820cacb4278e0bbc4ae137b)
With Senn 600's plugged in and nothing on the input jacks (no cables, no shorting plugs) just powered up and warmed up with volume control maxed out there is nothing coming out of the phones.  No hiss, no hum, nothing.
I did use shielded cable from the jacks to the pot and from the pot to the tube with shields drained to chassis by the added lug just in front of the pot.  Pot changed to Alps.
Offline JamieMcC
Reply #24 on: February 07, 2014, 10:00:23 PM
I had  a similar problem to this as well it was cured in my case by twisting my inputting rca cables together.
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fcdn.head-fi.org%2F7%2F7a%2F900x900px-LL-7ab2aec2_0092.jpeg&hash=3e0ef8569287b83ec1fec5d7e3f8b0b88ec0a737)
Offline Acclaim
Reply #25 on: February 08, 2014, 10:00:00 AM
Mike, you are definitely correct in adding in the shielded cable.
I did some testing today and came to the conclusion that a shielded cable will fix my problem. While manipulating the braided cable, I found that the hum lessened the further away the braided cable was from the components. If I hovered my finger tips between the braided cable and terminals 17, 18 and 19 the hum dropped off even more dramatically.
Offline Mike B
Reply #26 on: February 08, 2014, 10:50:31 AM
That's what I was thinking.  It was free too, I just used stuff that I had left over from Stereomour as I only wired 1 input.
If it is good for Stereomour, it will be good for Crack.  Yup, just add a lug to the chassis and drain one end only of the shields.
Reply #27 on: February 09, 2014, 09:00:07 AM
Mike,
Great advice.  I have a small spool of stranded shielded microphone wire from RS, Ca: 1972.  I have used it in a couple of builds and I have convinced myself it made a difference.
« Last Edit: February 22, 2014, 10:00:33 AM by Grainger49 »
Reply #28 on: February 10, 2014, 09:33:15 AM
If the input is shorted and it's silent it means the noise is coming in ahead of the input, i.e. from the cables or the source.
