Tube Burn in
mcandmar · 3962
on: February 09, 2014, 01:28:35 PM
I have noticed a trend with NOS 6DN7 tubes being very noisy and needing run for hours before they settle down.  What i am wondering if its just as simple as running the heater element to warm them up, or do they need current flowing through them to burn in?  Basically i'm thinking of putting together a simple rig just to power up the heaters and bed them in.  Has anybody tried this, or have any thoughts on the theory?
Cheers,
Mark
Reply #1 on: February 09, 2014, 03:26:48 PM
There are two physical effects I can think of:
1) "Forming" the cathode - requires plate current. Too much for a post; look it up in old books if anyone is interested.
2) The "getter" - usually a silvery flash on the inside surface - scavenges gasses from the vacuum; it takes heat to do this so the pore power the tube dissipates the faster the getter can function.
It is reasonable to expect both effects to be needed after a tube has been idle for a long time.
Reply #2 on: February 10, 2014, 03:46:06 AM
I've also just learnt the plates themselves heat up in operation and emit infrared radiation.  I thought the heater element was the only heat source, you really do learn something new every day.
Nevermind though, if its not as simple as just feeding them heater voltage its not worth the effort trying to build a rig.
Cheers,
Mark
Offline Natural Sound
Reply #3 on: February 10, 2014, 04:49:57 AM
Are you sure its the tubes and not the capacitors? I've found that interstage and parafeed caps need a long time to burn in. Sometimes hundreds of hours.
That said, I like to warm my system up for a while before a listening session. If I start listening from a cold startup I notice the sound getting better after the first hour or so. Admittedly that might be my ears "warming up" as well.
Reply #4 on: February 10, 2014, 09:01:30 AM
Positive, this is for new tubes that have never been used before, or have sat in storage for a few decades.
Offline Listens2tubes
  • Have you tweaked today?
    • Listens2tubes
Reply #5 on: February 10, 2014, 09:18:03 AM
My Dynaco MkIV amps need at least 30 min running my tuner at low volume to have full dynamics. Better an hour. As for burn-in I always have music playing.
Neal P.
Offline JamieMcC
Reply #6 on: February 10, 2014, 11:02:56 AM
+1 Yep I normally get in from work wash, change turn on the amp and it stays on all evening. If I am not listening I just put the playlist on repeat.
Reply #7 on: February 10, 2014, 11:18:35 AM
    .  .  .    I like to warm my system up for a while before a listening session.    .  .  .    Admittedly that might be my ears "warming up" as well.
I know I warm up to listening.  I pour 2 fingers of Bourbon 2 or 3 times a week for a listening session.  By the end, even after an hour of the system playing, I am warmed up.
« Last Edit: February 22, 2014, 09:58:37 AM by Grainger49 »
Offline Guy 13
  • Audio should be simple!
Reply #8 on: February 10, 2014, 04:38:10 PM
Hi all.
I don't need any warm up, here in Vietnam it's 95F.
My amplifier warms up very quickly
and even needs to be cool down with a fan
as it gets burning hot.
Guy 13
Rega P3/Exact MM / Rega Apollo / Decware SE84C+ / Bottlehead Crack / Sennheiser HD650 / Grace Mondo RIT/ Omega 7F OB dipole / Double Eminence 12" Acoustinator OB dipole.
Offline galyons
  • Geary Lyons
Reply #9 on: February 10, 2014, 05:43:48 PM
Hi all.
Guy 13
That's why there is Bia Saigon!!!
Cheers,
Geary
