Phones for Quickie
denti alligator · 12522
Reply #15 on: September 13, 2014, 05:42:48 AM
Ah, OK, well, that is the tap that we typically used, wired as an autoformer with the whole primary winding involved.  This makes essentially a 4K:250 transformer, which means that high impedance and high efficiency headphones are a good match.
I haven't tried Grados on the lower taps myself, but my gut feeling is that there won't be enough power available for them, but your mileage may vary.
Reply #16 on: September 15, 2014, 12:23:34 PM
THe problem with the Specos is that there were two versions, both with the same part number. The large Speco was about 2.2 inches between mounting holes, the small one 1.8 inches. I believe I have posted wiring and impedances for each of them.
Reply #17 on: September 15, 2014, 12:32:50 PM
You did indeed...
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fbottlehead.com%2Fsmf%2Findex.php%3Faction%3Ddlattach%3Btopic%3D5829.0%3Battach%3D5080%3Bimage&hash=1bd5b752393d770191d8fa7102e5b9f3ee0e2fbf)
Offline 20fenix08
Reply #18 on: September 29, 2014, 04:53:20 PM
A pretty decent sounding pair of headphone with high sensitivity and high impedance; I would suggest Urbanears Plattan. You can find them in stock at most BestBuys. You can find great deals online if color is not important. Plattan specs: sensitivity=115db; impedance=60ohms.
Reply #19 on: September 29, 2014, 04:54:22 PM
impedance=60ohms.
For the Speco modified Quickie, 250 Ohms is a good starting point.
Reply #20 on: September 29, 2014, 05:46:24 PM
That would be the "old speco" ... the "new" version should drive 60 ohms quite well.
Reply #21 on: September 29, 2014, 06:15:21 PM
115dB/...?
Unspecified specifications are so fun!
