Phones for Quickie
denti alligator · 12495
Offline denti alligator
on: February 15, 2014, 04:41:11 PM
Not to derail the thread, but what would be a good match for the converted Quickie?
« Last Edit: September 09, 2014, 01:42:31 PM by denti alligator »
- Sam
Online Paul Joppa
Reply #1 on: February 16, 2014, 11:57:52 AM
Well, biblically Mary Magdalene was said to have found Jesus a good match. But Bottlehead has very little expertise to offer on the subject of saving wayward ladies.
Oh wait, you mean a headphone that would match the Quickie-plus-Speco? Anything that meets both of the following two criteria:
1) Sensitivity greater than 105dB/mW. There are very, very few.
2) Matches the impedance of the available taps, which depends on which output transformer you are using. I've posted on those fairly recently.
Reply #2 on: February 16, 2014, 04:08:36 PM
Hah, nice one!
Can you point me to where you've posted on impedance ...
- Sam
Reply #3 on: September 09, 2014, 01:43:31 PM
Following up on this:
what is the impedance if I'm using the SEX 2.0 transformers*?
Also, what is  105dB/mW in SPL?
*mine are wrapped in gold-brown not yellow. are these the right ones (the old, not the new)?
« Last Edit: September 09, 2014, 02:26:05 PM by denti alligator »
- Sam
Reply #4 on: September 09, 2014, 03:57:18 PM
Bummer. Though those transformers are fairly cheap ($6 on ebay), so I may get some and try this mod.
I'm having difficulty figuring out what 'phones to pair it with. Can anyone help there?
- Sam
Reply #5 on: September 09, 2014, 04:33:11 PM
Try Grados.
Reply #6 on: September 12, 2014, 01:22:16 PM
Almost all the Grados have sensitivity of 99.8db, which would be too low, or?
Looks like Sennheiser HD598 is 112db sensitivity...
« Last Edit: September 12, 2014, 01:43:28 PM by denti alligator »
- Sam
Reply #7 on: September 12, 2014, 01:59:16 PM
The SEX 2.0 transformers are not Speco transformers, and do not have the appropriate taps for this modification.
A follow up on this. The transformers have T7010 on them. These aren't the Specos?
And if not, Paul Joppa suggested in the other thread that they might work:
Quote
You mean, I think, the oldest ones from before the Specos. Your transformers are very similar to the Speco, and should work about equally well.
Is this not the case?
- Sam
Offline fullheadofnothing
Reply #8 on: September 12, 2014, 02:09:22 PM
The Sennheiser spec is at a volt, not a mW, as PJ mentioned above. Assuming I did the math correctly, that's about 98dB/mW. The Senns also cost about 3 times more than the entry Grados. I've never heard them, so they very well may sound 3 times better. But I'd assume if you're trying to make a Quickie into a headphone amp, the goal is to keep costs low.
Reply #9 on: September 12, 2014, 02:12:50 PM
With my quickie the volume is close to being maxed out, but Grados are all about texture and detail not loud volumes and head thumping dynamics so its not a problem for me.
The output transformers have multiple output taps so you can experiment and find the ones that work best for whatever headphones you are using.
Reply #10 on: September 12, 2014, 02:14:35 PM
That 112db spec is in mW, I believe. At volt it is much lower. The latter is what Senn have on their site.
- Sam
Reply #11 on: September 12, 2014, 02:39:14 PM
Here's where I pulled the volt reference from.  http://en-us.sennheiser.com/audio-headphones-high-end-surround-sound-hd-598
Quote
Sound pressure level (SPL)    112 dB (1 kHz/1 Vrms)
Reply #12 on: September 12, 2014, 04:12:17 PM
I stand corrected.
So I ask again: what decent phones are above 108db?
- Sam
Reply #13 on: September 12, 2014, 08:03:41 PM
Ah, sorry, mixing up 2.0 and 2.1
Did you end up cutting off the 500 Ohm taps by accident?  (I think that was the brown wire?)
Reply #14 on: September 13, 2014, 03:17:17 AM
Nope. All the wires are in tact.
- Sam
