help on voltage check
bgf · 2577
Offline bgf
on: March 01, 2014, 07:53:56 AM
hi again thanks for your help. i have the following readings on my voltage check that differ from those in the manual.
10    190.4v
15    190v
22    217.5v
25    217.4v
40    217.1v
43    217v
46    217v
i assume this falls with in the acceptable range.
i am reading the "manual typos" section at the beginning of the posts as A2 and A3 as well as B2 and B3 are flipped.
my readings were
A2     101v
A3      0v
B2      97.3v
B3      0v
C3      4.83v (slightly out side the range in the manual)
is this okay.
brent fauss
Reply #1 on: March 01, 2014, 08:15:12 AM
You are correct, and your voltages look good.
