Recently Completed Stereomour - Hiss in Right Channel
Montigne · 74865
Offline Montigne
  • Industrial Designer
Reply #15 on: March 18, 2014, 12:13:09 PM
Paul,
Thank you again for the response. I have found a Vishay / Dale 665 ohms Metal Film Resistor on Mouser. It's specs are here (http://tinyurl.com/nlfscru), but basically it's: 665 Ohms, 125 mW (1/8 W), 1 % tolerance, 50 PPM / C, 300 V, Axial, and operatimng temperature of -65 C to +175 C. Will this work then?
Also, just to be sure I complete your previous instructions correctly: I add the resistors after removing the 431's, or do I leave them in and just bypass them with the 665ohms resistors in your steps?
Thanks, I'm getting excited to finish!
Stay in the groove.
Reply #16 on: March 18, 2014, 02:39:30 PM
When you remove the black wire going to kreg, the 431 is disconnected from everything except ground and can do no more harm to anything. Much easier to leave it in place!
The resistor you described is an excellent choice.
Offline borism
Reply #17 on: March 19, 2014, 05:21:22 AM
After reading the issue with the WS labeled 431s, I went back to check the make on the ones in my kit. I just completed my build and sure enough both are labeled WS. However, I haven't noticed any hiss in either channel. I should add that my speakers have a sensitivity of 92 (don't know if that matters).
Boris
Reply #18 on: March 19, 2014, 12:19:15 PM
This noise will be louder on more sensitive speakers.
We'll be trying a variety of 431s to get to the bottom of this. Yesterday I noticed that of the many manufacturers of this chip, only two have actual specifications for the noise, and they are about 10dB different from each other. It makes no sense to me, yet.
Offline Dr. Toobz
Reply #19 on: March 19, 2014, 12:29:35 PM
I was one of those unlucky persons whose 431's hissed like snakes on my 99dB speakers, so I went to cathode resistors. Would be happy to go back to the 431's (just for the sake of sticking to the intended circuit) if we can figure out which ones are consistently quiet!
Reply #20 on: March 19, 2014, 12:47:23 PM
There is a pattern. The guys with high sensitivity speakers are hearing the hiss. Owners of lower sensitivity speakers don't seem to be noticing it. Noise issues are not all or none, it's more a matter of degree. So what we can say is that we will do what we can to find a chip with a consistently lower noise level. But if you have really sensitive speakers and you hear noise that bothers you, you may have to use the alternative approach we have offered here anyway. That is the one of trade offs - along with reduced bandwidth - that you have to deal with when you go to very sensitive speakers.
Offline Dr. Toobz
Reply #21 on: March 19, 2014, 02:12:29 PM
I can confirm that the resistors don't sound noticeably worse or different than the 431's with my speakers, so the upside is that the alternative arrangement, when needed, still results in a wonderful-sounding amp.
Offline Montigne
Reply #22 on: March 23, 2014, 06:38:03 PM
Dearest Bottlehead,
Success. Hiss=gone. There is slightly more ground buzz than before with the 431s, but it's only when I have my ear right next to the driver and is completely unnoticeable when listening. Thanks for all the help so far Paul.
-Chris
Stay in the groove.
Reply #23 on: March 24, 2014, 12:05:58 AM
    .  .  .    only when I have my ear right next to the driver    .  .  .  .
You would probably find this in multi-thousand dollar commercial products, tubed and solid state.
Offline ffivaz
Reply #24 on: March 28, 2014, 11:58:33 AM
Hi,
I finally managed to get a new pair of 431s. Mine where noisy and read WS 431 on them. I replaced them with some FKA48 LM431 ACZ I found on the bay.
They are quiet as hell. My hiss is gone.
Thanks guys for finding the problem.
Fabien Fivaz
Thorens TD 160, Denon DL-110, Hagerman Piccolo 2, Reduction (w/ Integration), 2A3 Stereomour, Fostex FE126En in Bk12m enclosures
Halide DAC HD, Crack (w/ Speedball), Sennheiser HD 650
Offline borism
Reply #25 on: March 31, 2014, 04:17:46 AM
A naive question out of curiosity. Do you have to take off the small board to change the 431s (if a consistently less noisy type becomes available) or can it be done with the board in place (and how)?
Boris
Offline ffivaz
Reply #26 on: March 31, 2014, 08:46:37 AM
I had not too short pins, so I just cut the regulator out. Then with desoldering pump, I carefully removed the solder out of the holes, applying some heat. I finally was able to put the new regulator in and resolder it in place from the top, without removing the board. I was careful that the pins in the holes do not fall towards the socket and make some bad shorts.
BTW, I can send you some 431s. I received a handful. Just PM your address.
Fabien Fivaz
Reply #27 on: March 31, 2014, 09:04:49 AM
I thought I'd let everybody know that we quarantined the WS-431's that we had in our inventory, and have switched over to a quieter part.
Reply #28 on: March 31, 2014, 09:32:48 AM
Just what I would expect from Bottlehead.
Awesome!  !
« Last Edit: April 01, 2014, 02:14:21 AM by Grainger49 »
Offline bjorgens
Reply #29 on: March 31, 2014, 10:08:42 AM
PB, PJ,
Can you share the vendor/ PN for the quieter part you mention above?
Am wondering if its worth experimenting with different 431s on my paramounts (in hopes that I might remove the 10000uF caps I have across -reg and Kreg.
bryan
Bryan Jorgensen
VPI Traveler (Ortofon 2M Bronze)
Coffman Labs G1A preamp/phono/ headphone amp
Paramount 300B monoblocks
First Watt F4 clone
Blumenstein Orca Deluxe speakers and subwoofer
Cardas cabled Sennheiser 600s
