Pot recommendations
xcoolhandx · 9245
Reply #15 on: March 10, 2014, 09:20:29 AM
The first link goes to carbon film resistors, state of the art in the 70s but you would want metal film today.  The metal film is more stable at higher temperatures found in tubed equipment.
The second ones seem to be metal film but I can not find any indication of the makeup in the auction.
« Last Edit: March 31, 2014, 03:04:24 AM by Grainger49 »
Reply #16 on: March 10, 2014, 09:59:20 AM
I wouldnt be crazy about either.  The PRP are generally well spoken of but those listed are the general purpose range http://www.prpinc.com/?mod=product&id=2 and not their audio range http://www.prpinc.com/?mod=product&id=5.  What the difference is i dont know as both are metal film.
I have used the PR9372's in the past but personally i would just stick with regular Dale Rn55 resistors, at least they are a known quantity when used in the audio path.  Having said that i am not sure if they are in the audio path once a headphone is inserted into the socket, in which case anything will do.
Offline xcoolhandx
Reply #17 on: March 10, 2014, 10:05:38 AM
« Last Edit: March 10, 2014, 10:14:46 AM by xcoolhandx »
Reply #18 on: March 10, 2014, 10:19:49 AM
Offline xcoolhandx
Reply #19 on: March 10, 2014, 10:33:33 AM
they both 1/8W instead of 1/4 ..wouldn't this be a problem ?
Thank you
Reply #20 on: March 10, 2014, 10:53:12 AM
Should be fine, or is a 1/4w listed in the manual?
Offline xcoolhandx
Reply #21 on: March 10, 2014, 10:58:55 AM
yes it's listed in manual
Reply #22 on: March 10, 2014, 11:12:53 AM
It will be fine, the Mil spec Dales are under rated so the 1/8w items are actually 1/4w, and 1/4w are actually 1/2w etc. See here http://www.vishay.com/docs/31027/cmfmil.pdf vs the non Mil range http://www.mouser.com/ds/2/427/cmfind-239942.pdf.
Reply #23 on: March 10, 2014, 11:44:35 AM
One tenth of a watt would be fine here.  The current is minimal.
« Last Edit: March 31, 2014, 03:04:10 AM by Grainger49 »
Offline xcoolhandx
Reply #24 on: March 13, 2014, 10:38:20 AM
anyone have Noble AP25 hooked up to Crack ?
this should be same wiring as blue velvet right  ?
Offline galyons
  • Geary Lyons
Reply #25 on: March 13, 2014, 01:50:34 PM
This is how I did it:
Offline xcoolhandx
Reply #26 on: March 13, 2014, 03:26:43 PM
Thank you
Offline xcoolhandx
Reply #27 on: March 15, 2014, 09:31:20 AM
I like this PEC so much I might wait a bit before trying Noble ,also attached Dytons little different
Offline xcoolhandx
Reply #28 on: March 17, 2014, 07:35:32 AM
I didn't want to open up another thread for this but I like to know what I can use to reapply lacquer on transformer ,I was reading somewhere that  that the transformer is coated  with some type of lacquer mixed with stain ..can someone please tell me what kind of lacquer/stain ?
Thank you
EDIT; I try to order BH badge the other day ...
Quote
No shipping methods were found; please recalculate your shipping or continue to checkout and enter your full address to see if there is shipping available to your location.
« Last Edit: March 17, 2014, 07:56:32 AM by xcoolhandx »
Offline corndog71
Reply #29 on: March 17, 2014, 07:51:01 AM
I've been a fan of PEC pots for years.  Reasonably priced and great sounding.
Rob
