No sound after upgrade install [solved]
mcwhart · 11030
Offline mcwhart
Reply #30 on: March 23, 2014, 12:09:50 PM
Very sorry about that.  Meter was on auto setting.
Here we go again:
Volume Pot all the way up with power off and 60 Hz tone:
top lugs, from A side to B side:  .5 mV, 1.377 V, 1.377 V
bottom lugs, A side to B side:    .5 mV, 1.039 V, 1.039 V
Volume pot all the way up, Power on, 60Hz tone:
A1: 17.36 V              B1: 23.1 V
9:   17.38 V              19: 23.1 V
Thanks for your help and patience
Reply #31 on: March 24, 2014, 12:12:04 AM
Ok, the signal is getting through to these points.  A lot of signal!
Offline mcwhart
Reply #32 on: March 24, 2014, 02:03:55 AM
Is a lot of signal good or bad at this point?
Reply #33 on: March 24, 2014, 02:19:41 AM
Let me make sure I am following you.  The first measurements should be from the three lugs on each side of the pot to ground or the chassis.  The second measurements are to pins 1 of each tube (grid of the second stage).
If you are measuring this, you are getting amplification from the volume pot (about 1V) to the grid of the second stage of the tube (17V AC/23V AC).  That is what is supposed to happen.
You should also get more AC voltage on pin 2 of each tube.
Offline mcwhart
Reply #34 on: March 24, 2014, 05:03:15 AM
Yes, this is correct.  By lugs on the pot I am assuming you mean the upper and lower row of three tabs, or lugs(?) on the volume pot.  Those are where I took the first six AC voltage measurements, followed by A1 and B1, then 9 and 19.
Reply #35 on: March 24, 2014, 05:04:45 AM
Yes, we are moving in the right direction.  I'm guessing it will be something silly like I did 2 weeks ago.  So far you are doing all right.
Offline mcwhart
Reply #36 on: March 24, 2014, 05:16:21 AM
Great.  Thanks!
Offline mcwhart
Reply #37 on: March 25, 2014, 01:33:53 AM
Any suggestions as to where to go next with this?  Thank you
Reply #38 on: March 25, 2014, 03:53:35 AM
The output section of the tube is pin 2.  You should have DC and AC amplified voltage there.  You should be able to turn it on, re-verify the AC voltage on tube pin 1 then you should read more on pin 2 of each channel.
If the DC there messes with the reading measure instead to terminals 20 and 40.  That is after the Parafeed cap and the input to the output transformers.  There should be a transformer wire on terminals 20 and 40 as well as the Parafeed cap.
If you get amplified voltage on these terminals the signal is dead somewhere in the transformer wiring to the speaker outputs.
Or, maybe, the headphone jack has failed and permanently opened the circuit to the speaker outputs.
Reply #39 on: March 25, 2014, 06:24:22 AM
Your C4S upgrade is working perfectly, we can now move completely away from that as a source of not having sound.
Grainger is correct, pin 2 on each tube socket is the next place to measure voltage.
Then terminals 15 and 25.
Then where each red wire connects on the binding posts.
Offline mcwhart
Reply #40 on: March 25, 2014, 10:47:08 AM
Here are the AC voltage readings I get for points you indicated:
A1: 16.5v
A2: 218v
B1: 23.2v
B2: 239v
Terminal 20: blinks back and forth between about 240v and about 405v
Not sure where terminal 40 is?
Terminal 15:  222v
Terminal 25:  246v
Binding Post red wire on A side:  8.15v
Binding Post red wire on B side:  9.03v
Thank you
Reply #41 on: March 25, 2014, 10:50:53 AM
You have sound coming out of your SEX amp...
Offline mcwhart
Reply #42 on: March 25, 2014, 01:26:46 PM
Ah, yes I do.  Thanks for your help.
 Still a low level hum that was not there before attempted upgrade install, and the right channel is definitely louder than the left.  Tried switching tubes and connection wires, no change.  Any ideas about what might be causing that?  The amp was much quieter and balanced before the upgrade than it is now.
Offline mcwhart
Reply #43 on: March 26, 2014, 08:04:37 AM
Any advice as to where I should be looking to resolve low-level hum issue and stronger signal from right channel?
Thank you
Reply #44 on: March 26, 2014, 08:46:07 AM
Your tests revealed that the voltage coming into the SEX is out of balance.
Low level hum could be from a loose wire or a capacitor that only has one lead well soldered.
If you have this hum in both channels, look at the 220uF/250V caps first.  I generally will poke at them with the amp off and be sure that when they move, they move with the terminal strips, not independently from them.
