Bottlehead Kits
Crack
Voltage check on A4,5,9, B7,8 reads 194V. Problem? [solved]
geekosphere101
4728
Mike B
Full Member
Re: Voltage check on A4,5,9, B7,8 reads 194V. Problem? [solved]
Reply #15 on:
March 17, 2014, 04:45:47 PM
Why is being able to have the volume set to zero important?
I do not have one piece of gear with a volume control set to zero. I never ever set a level control to zero. That means you get zero sound.
Grainger49
Hero Member
Reply #16 on:
March 18, 2014, 12:14:30 AM
I think with the Crack folks believe setting the volume at zero will keep the turn on thump from coming through. That isn't the case, of course since it is on the input.
And I could be wrong.
But there have been a trickle of volume controls that lift at zero leaving the input "open" recently.
Last Edit: March 19, 2014, 11:39:45 AM by Grainger49
Bottlehead Kits
Crack
