Bottlehead Kits
Legacy Kit Products
Paramount
voltage check
voltage check
bgf
3346
bgf
Jr. Member
voltage check
March 22, 2014, 09:44:06 AM
just checking with you before i hook things up some voltages are different from the manual
term amp A amp B
9 174.5 174.5
19 174.4 174.5
kReg(A) 3.6 2.78
oB 174.5 174.5
thanks you all have been a great help with this build
brent fauss
Paul Birkeland
Global Moderator
Hero Member
Re: voltage check
Reply #1 on:
March 22, 2014, 08:11:13 PM
You can trim the little blue trim pot on the driver PC board to adjust those voltages closer to 200, but at 175V, you're in the ballpark.
If you built the 2A3 version, then the bias voltage is set a bit lower.
bgf
Jr. Member
Re: voltage check
Reply #2 on:
March 23, 2014, 06:58:31 AM
the build was a 300b. plugged them in and they sound great with the BeePre and eros. thanks again.
brent fauss
Bottlehead Kits
Legacy Kit Products
Paramount
voltage check
