Problem with speedball upgrade
xiawei · 8078
Offline xiawei
on: March 23, 2014, 02:13:58 PM
Before the upgrade all readings were right and both LEDs (A3 and A8) lighted.
However, after the upgrade, the voltage reading of terminals 5 (-380mV) and 9 (50V) are not right. The rests are spot on. Also the LED connecting A3 doesn't light.
During the building of the speedball, the 3 pads of B+ that connects individually with 2U, the resistor and the other B+  are too close, during the soldering I wasn't sure if they touches each other. I assumed they were the same. And  I haven't tested how it sounds yet….
Thanks a lot for the help!
Reply #1 on: March 23, 2014, 02:18:08 PM
The "I" and the "O" pads need to not be soldered together.
The "I" pads and the closest leg of R1 are all connected on the board, so that's not a problem.
The LED on A3 not lighting and 0V on T5 means that you need to reheat the center leg of the MJE350 on the right PC board.
Offline xiawei
Reply #2 on: March 23, 2014, 02:53:01 PM
Thanks for the quick reply!
What does 'The "I" and the "O" pads need to not be soldered together' mean?
Offline xiawei
Reply #3 on: March 23, 2014, 02:57:53 PM
I just re-wet the middle foot of MJE350 but the A3 LED still does not light..
Offline xiawei
Reply #4 on: March 24, 2014, 04:22:32 AM
Any ideas? Could be any defect parts?
Reply #5 on: March 24, 2014, 04:36:29 AM
The I and O pads are the input and output of the C4S board.  Having them soldered together jumpers around the whole board.
There are IA and IB, OA and OB solder pads marked on the top of all three boards.
Offline xiawei
Reply #6 on: March 24, 2014, 05:52:34 AM
Is and Os are quite far, I didn't short cut between Is and Os. They were the 3 B+ pads that are too close and I was sure they was together.
Any ideas why the A3 LED doesn't light? Before speedball upgrade everything was fine. I double checked and found A2 touched A1 ,which I believe happened during I made spaces for the nylon standoffs. I separate them but everything stays the same, voltage readings and the non-lighting A3 LED.
Reply #7 on: March 24, 2014, 06:48:52 AM
A3 won't light if the board that feeds that half of the tube isn't functioning.
0V out of the board generally means that parts aren't well soldered on that board.
Offline xiawei
Reply #8 on: March 24, 2014, 08:46:26 AM
Thanks! Although I doubt a bad solder could occur, I will re-do the solder connecting O pad to T5 and that connecting T5 to A2 after the work. Hope this is where the problem is..
Offline xiawei
Reply #9 on: March 24, 2014, 02:26:15 PM
I re-solder every parts of the speedball and reconnect it with the amp. But the same problems remain.
The right channel sounds ok but the left hums with lots of noise, which changes little when I touch the aluminum plate. even more changes when I touch the small tube. Could it be a bad tube socket? The reason I'm saying this is A2 accidentally touched A1 when I turned it on the first time after the upgrade?
Please help! Really frustrated here.
Reply #10 on: March 24, 2014, 02:41:51 PM
It is probably not a bad tube socket or a bad part (unless it was damaged in installation).
Most likely it is a problem with the ground.  Go to the Crack folder read and follow the sticky thread about checking the ground path.
Offline xiawei
Reply #11 on: March 24, 2014, 03:55:31 PM
It passed all ground tests. Could improper ground cause the A3 LED not to light? How to test the A3 pin is OK? Or maybe a broken LED?
My stock build that was sounding so good - and my work only turned it into something that doesn't work at all….
« Last Edit: March 24, 2014, 05:28:54 PM by xiawei »
Reply #12 on: March 25, 2014, 01:46:11 AM
Yes, the A3 LED should have a wire to ground from the center pin of the tube socket.  So a ground problem would keep it from lighting.  But if the other LED glows that verifies the ground is good.
"Humming with lots of noise" is often a grounding problem or an open hot lead from the RCA jacks.  In my experience, an open hot lead has a hollow sound to it rather than the normal hum.
Offline xiawei
Reply #13 on: March 25, 2014, 02:09:00 AM
yes, all other 9 leds light. i would describe the left channel muffled, with very low volume and some hums. now i doubt the led is dead, anyway to verify that without taking it off? also could it be the a3 pin or the correspoding leg on the tube?
Reply #14 on: March 25, 2014, 03:44:00 AM
If your meter has a diode check position read the manual and see how it should be used.  Then check the LED.
If not, set it on a resistance range like 200 Ohms and check first with the red lead at the tube pin and the black lead on the socket center pin.  Better yet, put the black lead on the top plate; this verifies continuity to ground.  This reading should be a measurable resistance.  Report it back.
Then put the black lead on the tube pin and the red lead on the tube socket center pin you should have infinite resistance, or something above 1M Ohms.
Report your findings back.  We can at least verify that last LED and move on to the circuit boards.
