My Fix
BNAL · 13189
Offline BNAL
on: March 29, 2014, 10:02:52 AM
I finally got a chance to measure my Orcas and Yamaha subs (YST_SW215) and saw that the the bottom and top ends were rolled off. My initial setup was with the Fix set to 2db at 10K and narrow baffle and 2db boost. After running a sweep I did not realize that I was missing so much from the low and top ends. I made some adjustments on the subs, raising the the cutoff from about 70hz to 90hz and increasing the volume. I also, changed the BS to 4db and the high end to 20K. Now things are dialed in much better. I still need to do some more listening and measurements, but things sound much better and I could not have done it without the Fix.
Thanks for the great product.
Brad Nalitt
Iron Upgraded S.E.X. Amp 2.0
Foreplay III
Quickie w/PJCCS
Eros Phono
Offline johnsonad
Reply #1 on: March 29, 2014, 11:24:29 AM
I really should put mine together..... Glad it's working out for you Brad!
