pdrm360 · 6531
You can try swapping the small boards right to left, if the voltage issue migrates to terminal 5, you have a flaky connection on the board.If it doesn't move, you have a flaky connection at A8, A7, or A6, and the parts those connect to.
Since A1 is connected to terminal 5, can you see if the voltage is jumpy there also?-PB
The TIP-50 transistors are on the larger PC board, which seems to be OK.I believe you may have a flaky solder joint on that small PC board that is now feeding terminal 5.
