Bottlehead Kits
Mainline
Voltage test problem + 2 LEDs dark [solved]
George Napalm
5667
George Napalm
Jr. Member
April 14, 2014, 06:09:09 PM
Hello everyone,
I finished building my Mainline a couple of days ago. Power supply test and resistance check were fine. But the voltage test brought the following problems:
+275vDC on the Power Supply Board: 278
+6.3vDC on the Power Supply Board: 6.2
IA on the A side C4S Board: 276
IA on the A side C4S Board: 274
Breg Regulator Board A side: 216
Breg Regulator Board B side:
142
-reg Regulator Board both sides: 0
Kreg Regulator Board A side: 11
Kreg Regulator Board B side:
58
In addition to that, 2 LEDs on B side of the right-side C4S board are dark. I've seen similar problems with other users, but their voltage readings were quite different. I've rechecked all connections on the Regulator Board and the right-side C4S board, as well as B and C sockets. I also resoldered some suspicious-looking connections on the rights-side C4S Board and Breg Regulator Board B side, but the problem persists.
I also need to mention, that I seem to have different 431 regulators: A side one has "WS TL 431A", B side has "FKB31 LM 431" written on them.
Does anyone has ideas what is the problem here? Thanks in advance.
Pictures:
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi961.photobucket.com%2Falbums%2Fae93%2FGeorgeNapalm%2F_4110132_zpsc7fea2fc.jpg&hash=a274380788d494b054e64f07069f26bd2bb9c7b7)
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi961.photobucket.com%2Falbums%2Fae93%2FGeorgeNapalm%2F_4110136_zps46342cec.jpg&hash=058ab916a2ed068873c7f9041eeb9e83df402df9)
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi961.photobucket.com%2Falbums%2Fae93%2FGeorgeNapalm%2F_4140144_zpsee7efd7c.jpg&hash=e3812f02b539f877f510c683a3fe94106d6b0b59)
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi961.photobucket.com%2Falbums%2Fae93%2FGeorgeNapalm%2F_4140146_zpse7ff3dc6.jpg&hash=1bbf242c271c9d4b3dfd1d55a5adf1360ead43b1)
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi961.photobucket.com%2Falbums%2Fae93%2FGeorgeNapalm%2F_4140148_zps8ff0ef5b.jpg&hash=8397cd010e730be3d3b73e01433f5fedb917c9bc)
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi961.photobucket.com%2Falbums%2Fae93%2FGeorgeNapalm%2F_4140149_zps32cfbc4a.jpg&hash=9dda7f55525b0fefa992db64807215fd6faef877)
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi961.photobucket.com%2Falbums%2Fae93%2FGeorgeNapalm%2F_4140152_zps2ccf42d1.jpg&hash=72bf9849f43b1845e6559fdb5d62dbe1b82f080f)
Last Edit: April 14, 2014, 07:50:02 PM by Caucasian Blackplate
Heorhi Zhyhalko, Belmont, MA
Paul Birkeland
Global Moderator
Hero Member
Re: Voltage test problem + 2 LEDs dark
Reply #1 on:
April 14, 2014, 06:36:28 PM
Pull the 12AU7, then measure the voltages at IA, OA, IB, and OB on the B side C4S board.
George Napalm
Jr. Member
Reply #2 on:
April 14, 2014, 07:00:24 PM
IA: 285
OA: 283
IB: 283
OB: 172
George Napalm
Jr. Member
Reply #3 on:
April 14, 2014, 07:06:30 PM
And I got similar results on the left-side C4S board, but OB on the left (A) side was 180
Paul Birkeland
Global Moderator
Hero Member
Reply #4 on:
April 14, 2014, 07:17:59 PM
Can you use the bias trim pots to trim out your OA voltages to more like 150V?
I'm just whittling down possibilities here.
George Napalm
Jr. Member
Reply #5 on:
April 14, 2014, 07:36:55 PM
A-ha! I reinserted the 12AU7, then set the bias to 145 on both sides - and all my LEDs are now on! And those offending voltages are normal now: Kreg on both sides are 11V and Breg are both 217V.
I guess I'm all set! Thank you so much! I'll do listening tests tomorrow.
George Napalm
Jr. Member
Re: Voltage test problem + 2 LEDs dark [solved]
Reply #6 on:
April 17, 2014, 03:05:31 AM
I did the listening test yesterday and had a bit of a scare. There was a big channel imbalance (on all volumes). After verifying that attenuators are built correctly I decided to double-check the tube bias. And indeed it drifted to 155 and 135 volt on left and right sides. I must have done the initial biasing before the amp warmed up properly. I waited for 10 minutes and set the bias voltage back to 145v on both channels. It totally fixed the problem.
The amp is up and running and produces beautiful sounds :-) Thanks Bottlehead for terrific product and excellent support!
Bottlehead Kits
Mainline
