Our new preamp kit - Smash
Doc B. · 38736
Reply #15 on: April 21, 2014, 12:36:02 PM
Wish I could justify getting onee, but not at least until the backlog is taken care of.
Yeah, you sure have a lot of projects going!
Offline xcortes
Reply #16 on: April 21, 2014, 01:07:18 PM
Paul,
How complicated is the build? Again, the quickie being one and the BP 10 I would assume a five.
Xavier Cortes
Reply #17 on: April 21, 2014, 03:26:07 PM
PB,
Yes, but now I have a lot more energy and overall better health plus a nice electronics work area and a decent wood shop, so other than idintifying terminals and dealing with circuit boards, no real roadblocks. Oh, and with the analysis paralysis out of the way and a real plan in hand, the work feels fun and nicely mapped out for me.
Reply #18 on: April 23, 2014, 04:25:34 AM
Crackphones and Smash in a couple of months. It doesn't sound like anybody at BH headquarters is coasting.
I want 'em both!
Offline Mr. Davis
Reply #19 on: April 25, 2014, 12:05:54 PM
Doc,
Can you give us some hints of what this new (middle price range) power amp will be?
Perry Davis
Reply #20 on: April 25, 2014, 12:11:48 PM
It will be EL84 based, about 4.5 watts per channel. As usual we are doing things a little differently than others. I will give some more info once we are a little farther along with the project.
Reply #21 on: April 25, 2014, 01:44:19 PM
I thought I'd also mention another feature in this thread that didn't make it into the announcement.
With the particular regulator that we are using, I am able to limit the maximum available current that the regulator will output.  For a directly heated tube, the filaments draw considerable more current when cold than when warmed up.  This puts a reasonable amount of stress on the filaments, so by limiting the current draw at start up, we can extend tube life a bit.
It is worth mentioning that this is a phenomenon that tube manufacturers are aware of and design for, so it is not mandatory and we do not plan to retrofit it into other kits.
Offline dougmon
Reply #22 on: April 29, 2014, 11:31:08 AM
I hope I didn't miss something in reading about this, but the specs say one of the outputs can be used for a dedicated headphone amp. Does this mean one of the outputs can be wired as a fixed volume line out?  Will there be instructions to do this?
Reply #23 on: April 29, 2014, 11:49:40 AM
You could wire a Tape Out to one of the outputs for this purpose, but I would instead recommend using the Smash as a buffer to drive your headphone amp instead.
Offline Cleet Torres
Reply #24 on: May 05, 2014, 04:43:25 AM
Doc, am I assuming correrctly that the price range of the new amp will be below the Stereomour?
I cannot quite swing the $$ for Paramounts but I was toying of building Stereomour poweramp - sans selector, volume etc to run off my foreplay III (and soon my Smash).
How will the new amp compare with the stereomour? When I read "EL84", which is a nice sounding pentode for sure, I'm thinking it's not going to be able to compte with a 2A3  stereomour no?
Cleet.
Reply #25 on: May 05, 2014, 05:19:33 AM
Yes, the EL 84 amp is intended to cost less than the Stereomour and give the same or a little more power. We are still working up the design at this point and thus it's premature to make some definitive statement about how it sounds.
Offline Sonido
Reply #26 on: July 05, 2014, 01:03:33 PM
Out of curiosity, does rolling the center VR tube do much in terms of affecting the sound?
Reply #27 on: July 05, 2014, 02:25:31 PM
Rolling the bypass cap on it probably has more impact.
Offline Mr. Davis
Reply #28 on: July 06, 2014, 06:17:57 AM
Are you talking about the  .1 uf 400V film capacitor? I was wondering about that.
Perry Davis
Reply #29 on: July 06, 2014, 06:33:36 AM
If Smash follows the FP III regulator circuit a USSR Military surplus 0.1uF@600V bypass will sound better there.
