Problems after speedball(Solved)
Strikkflypilot · 8898
Offline Strikkflypilot
  • Shellac fiddler
Reply #30 on: May 05, 2014, 09:40:16 PM
Thanks for all help thus far, CB.
I Removed all transistor/LEDs on the dark half
LEDs had no voltage drop, even out of curcuit
The 2N2222A was kinda dark/ blueishblack and burned looking
The TIP50 looked good but I changed it all the same.
After reconnecting, all LEDs lighted up and Voltages are good.
Just haven't had time to listen in yet. Very excited
« Last Edit: May 06, 2014, 06:11:47 PM by Strikkflypilot »
Home system:
DAC: Schiit Gumby
Amp: Bottlehead Mainline
Phones: HD800S
Office:
Sources: Iphone/ Ipod
DAC: Dragonfly Red+Jtrbug
Phones: HD580,HD600 grilles
  • Shellac fiddler
Ok.
Was excited to try some music
I switch the crack + SB on.
After about 6 seconds the 6080 lights up blueish before it lights as usual(wires in reddish light) after about 10 seconds, when a humming starts (about 80-85 Hz like a ground loop?)that is first noticabe on the left, then also on the right channel although slightly weaker. This humming gets considerably louder up to 20 seconds. On a cold amp it wears out at about 60 seconds. Faster on hot amp, maybe 15 seconds after it gets loud.
From then on it is quiet until I turn the volume all the way down which makes the noise on both channels with max noise. When I turn the volume all the way up to 100% it is also noise with left>right. In between it is quiet
If I attach a source, there is only a slight hum which gets louder from about 70% volume to 100%. Ig I turn volume all the way down, the noise is back to max binaurally.
In between, as in 0%<,>100% the Sound quality seems sweet, but it is overshadowed by the other issues...
Again I ask for help. And of course, here are the voltages witj SB installed:
1. 73,4 v
2. 173,45 v
3. 0 v
4. 173,41 v
5. 76,8 v
6. 0 v
7. 101,86
8. 0 v
9. 102,8 v
10. 0 v
11. 0 v
12. 0 v
13. 173,1 v
14. 0 v
15. 192,33 v
16. 0v
17. 0 v
18. 87 v
19. 82,7 v
20. 0 v
21. 211,4 v
Hope this can be resolved.
Yours truly
Home system:
DAC: Schiit Gumby
Phones: HD800S
Office:
This is noise that occurs during warmup, there isn't really anything to troubleshoot here.
  • Shellac fiddler
Good to hear, really, but the constant noise at volume level 0 and the blue flash in the 6080 at 7 seconds is nothing to worry about or possible to mend? (ESpecially the volume 0 buzz is rather annoying and wasnt there before the SB)
Home system:
DAC: Schiit Gumby
Phones: HD800S
Office:
The warmup characteristics of the amplifier change when installing the Speedball.
If you can't live with a bit of warmup time, you can reinstall the 22K resistors.
  • Shellac fiddler
Thanks again for the reply. Appreciate Your diligence with this matter.
I can certainly live with the warmup time, just wasnt expecting it.
Is there a way to eliminate the loud buzz at 0 volume? It does NOT go away.
« Last Edit: May 06, 2014, 05:26:55 PM by Strikkflypilot »
Home system:
DAC: Schiit Gumby
Phones: HD800S
Office:
I am looking into replicating the issue with one of our Cracks and coming up with a solution.
  • Shellac fiddler
Reply #37 on: May 06, 2014, 06:08:10 PM
Well, Caucasian Backplate.
After leaving it on a couple more minutes, also the 0 Volume buzz disappeard, like You said.
Shame on me :-[
I thank You very much for ALL Your help.
My amp is now working as designed.
Long Norwegian summernights with the classics ahead:)
Home system:
DAC: Schiit Gumby
Phones: HD800S
Office:
Offline pduk
Reply #38 on: May 07, 2014, 01:35:07 AM
Hi Strikkflypilot,
I have the exact same behaviour with my Crack+Speedball built a couple of weeks ago. Stock crack was completely silent, then with the speedball fitted I get mains hum at the start, getting louder then receding, and a low-volume buzz that goes away after a couple of minutes. I did all the suggested checks and am satisfied that the build is OK. I am more than happy with the sound. It did scare me the first time I heard the hum as I feared it would get ever-louder and break my HD650s (not to mention my ears) but happily not.
Cheers
Paul.
  • Shellac fiddler
Reply #39 on: May 07, 2014, 02:08:31 AM
Thanks, pduk.
Nice to get that kind of feedback from a fellow builder.
Caucasian sure has walked me through this very thoroughly.
I hope the questions asked and answered will help those that also eventually will have questions of their own when building.
I could not be happier with the support here.
My most important tip for upcoming builders is this:
Check all solder joints! Not only by looking but with Your Multimeters.
Home system:
DAC: Schiit Gumby
Phones: HD800S
Office:
