General Category
Technical topics
Use of ECC804 in Crack
Guest ·
3274
Loon
Guest
May 18, 2014, 01:37:31 AM
I am toying with the idea of experimentally using an ECC804 as the input tube in the Crack. It seems quite similar to the ECC82 and is dirt cheap.
One question I have is the assignment of the ninth pin. The 12AU7 has pin 9 as centre heater tap and the ECC804 has pin nine as a shield. A quick look at the Crack circuit shows grounding of pin 9. Is it fine to ground the shield? What is the role of this shield?
Cheers
http://www.r-type.org/pdfs/6-30l2.pdf
Last Edit: May 18, 2014, 02:52:47 AM by Loon
Loon
Guest
Re: Use of ECC804 in Crack
Reply #1 on:
May 18, 2014, 02:23:22 AM
Next Question:
A quick look at the Va Ia curves shows a desirable plate current of about 9mA in the circuit (staying with a -1.5V bias) for the ECC804. How do I calculate the value of R1 in the Speedball to achieve this current?
Thanks again in advance!
Paul Birkeland
Global Moderator
Hero Member
Reply #2 on:
May 18, 2014, 02:26:36 PM
It looks to have the same pinout as the 6DJ8. The 6.3V twisted pair of wires would go to A4/A5, and A9 should be grounded, preferably to the chassis at T3.
I don't see a great set of plate curves available.
Loon
Guest
Reply #3 on:
May 18, 2014, 05:26:10 PM
Please follow link in post 1 for curves.
How do I calculate R1 on speedball of a 9mA constant current output?
Paul Birkeland
Global Moderator
Hero Member
Reply #4 on:
May 18, 2014, 05:46:26 PM
R1 is about 0.855/current. I'd bump R2 to a 100K/2W part.
Loon
Guest
Reply #5 on:
May 18, 2014, 06:10:35 PM
Awesome! Thanks Paul. If I can get into the ballpark with resistor values I can always fine tune values.
This pinout should also work with an E288CC. Thinking of playing with this as an input tube to get an OP for the 5998 and 7802 with a lower voltage (around -50V grid voltage), which I expect to be able to achieve running with a -1.5v bias on E288CC and plate current of about 8mA.
Fingers crossed. Hope nothing explodes!
General Category
Technical topics
