Bottlehead Kits
Crack
Repositioning TIP-50 Transistors
Evan
2282
Evan
Jr. Member
May 19, 2014, 05:50:21 PM
The wood enclosure that I built for my Crack is shorter than stock, enough so that the Speedball heat sinks stick down far enough to not allow the top plate to rest flat. Would it be okay to attach the TIP-50 transistors to the aluminum top plate itself and then run a bolt through the top plate and into a heat sink like the one I've attached (using some thermal adhesive for better heat transfer)? I'd then run short leads from the transistors to the PCBs with heat shrink over the pins to prevent shorts. The heat sinks would be positioned on either side of the ventilation slots. I thought it might be an interesting visual addition as well. The data sheet for the heat sink indicates 72 degrees C at 4 watts.
Potential Heat Sink:
http://www.digikey.com/product-detail/en/695-1B/345-1095-ND/655563
Stereomour => SEOS Fusion 12 Tempest
Crack => Senn HD600
Paul Birkeland
Global Moderator
Hero Member
Re: Repositioning TIP-50 Transistors
Reply #1 on:
May 19, 2014, 07:49:26 PM
Chassis plates are miserable as heatsinks, and any heatsink you mount on top of them will have reduce effectiveness. How much additional clearance will you need? I'd imagine that shorter nylon standoffs would be a safer choice.
JamieMcC
Hero Member
Reply #2 on:
May 19, 2014, 08:58:12 PM
I used some rubber door stops for feet to gain a little extra clearance it also allow better ventilation for cooling
Grainger49
Hero Member
Reply #3 on:
May 19, 2014, 11:52:15 PM
I'm with Jamie, feet are in order for air flow and in your case clearance. If you need more clearance than a foot would give you go with spikes of some sort.
Bottlehead Kits
Crack
