Paramount 220v version
Demsy · 14902
Offline Demsy
Reply #15 on: May 29, 2014, 03:25:40 PM
Grainger, our line voltage here is 220v daytime and could go down to 200v at night. For this I already use a 5kVA automatic voltage regulator, which is now set at 220V. I also connected a manual slide regulator, set at 240V, to it. Of course I can bring the voltage up to 250V, but the point is to find out first why the filament voltage is still below the specified 5V even at 240V. I really don't have the desire to keep the chain of regulators in my music room.
Reply #16 on: May 30, 2014, 01:00:36 AM
Ok, I had not read that you had brought your input to the Paramounts to 240V and still not brought the heaters to spec.  Sorry!
I'd say Paul Joppa will come up with the answer.
« Last Edit: June 03, 2014, 12:47:01 AM by Grainger49 »
Offline Demsy
Reply #17 on: June 02, 2014, 04:03:28 PM
PJ, if the line voltage were set 250V, would there be any negative consequences for the transformator and it's other outputs?
Reply #18 on: June 02, 2014, 07:05:25 PM
>>> "PJ, if the line voltage were set 250V, would there be any negative consequences for the transformator and it's other outputs? "
No, none.
I have developed a preliminary set of recommendations to give the 5.00 volts with line power of 220, 230, 240, and 250v, and interpolation will allow intermediate voltages to be accommodated. I am not yet ready to post them.
Offline Demsy
Reply #19 on: June 02, 2014, 10:20:39 PM
Thanks PJ. Good to know that the recommendations are on it's way!
Offline Demsy
Reply #20 on: June 16, 2014, 02:30:52 PM
Any progress so far, PJ?
Reply #21 on: June 16, 2014, 02:37:14 PM
PJ is away for a week or two.
Offline Demsy
Reply #22 on: July 14, 2014, 01:15:51 AM
Hi PJ,
How's the development of the recommendation?
Reply #23 on: July 14, 2014, 02:38:50 PM
Sorry for the delay; several of us have been absent off and on and out communication is a little haphazard!
I have given Doc B a draft writeup which he will probably post on the site once we are all agreed it's satisfactory. Meanwhile, for the specific problem of a Paramount on 220v, the best solution is fairly simple:
1) Wire the filament power choke as if it were for a 2A3. This will reduce the DC resistance from 0.6 ohms to 0.15 ohms, raising the voltage about 0.55v. The exact change depends on some uncontrollable variables such as the amount and type of distortion on the power line voltage.
2) It will also increase the hum a bit; if this is a problem you can place a 10000uF/10v to 16v cap across the output of the choke (positive to choke terminal 6, negative to terminal 1). This capacitor can be used with any Paramount to reduce the very small residual filament hum.
Offline Demsy
Reply #24 on: July 15, 2014, 07:06:37 AM
Will the final solution be the same as what you've written? I'm not comfortable with the increased hum and additional components. I plan to use a high sensitivity (105db) loudspeakers in the near future.
Reply #25 on: July 15, 2014, 08:00:17 AM
I would recommend trying the choke rewiring.  If it does elevate the hum, then pop the cap across the output of the choke.  (10,000uF/16V)
Reply #26 on: July 15, 2014, 11:19:09 AM
With 105dB speakers (!) I would certainly add the capacitor. It will then be much quieter than the normal (240v) stock build.
In the proposal I made (the draft article) I tried to avoid using complicated or difficult modifications. The suggested mod will work well *5.00 +/- 2.5%) for voltages in the range 220-230 volts. There are different versions for 230-240v and 240-250v, and the stock circuit is excellent at 250-260v.  In my opinion greater precision is not warranted in light of fluctuations in available power.
Offline Demsy
Reply #27 on: July 15, 2014, 02:47:40 PM
Thanks PJ and PB.
Would this apply for both of the 300B and 2A3 tubes?
Reply #28 on: July 15, 2014, 05:12:34 PM
No, the 2A3 is different and more complicated.
Offline Demsy
Reply #29 on: August 04, 2014, 12:24:42 AM
PJ, easiest for me is to bring the line voltage up to 255v instead of the other mods, as you mentioned that for 2A3 it's different and more complicated changes are needed.
