problems after installing the c4s boards (FIXED)
wesleyHK · 11846
Reply #15 on: June 15, 2014, 08:31:51 AM
It shouldn't be embarrassing, just part of the building process. This us why we always suggest that builders touch up very joint if they can't locate a single one that is making the noise. It only takes a couple minutes and it isn't always possible to see that a bad joint is bad.
If you guys saw how much s**t we blow up in the lab you probably wouldn't sweat the cold joints and miswires so much.
Reply #16 on: June 15, 2014, 08:53:22 AM
Yeah, you missed me accidentally installing the 220uF 250V cap in the 400V power supply on Friday.
Reply #17 on: June 23, 2014, 06:23:06 AM
Thank you Doc and Paul for those last 2 posts, and all your help on my builds.
