New build voltage question
SeanHolcombe · 2134
Offline SeanHolcombe
on: June 30, 2014, 04:28:48 AM
Hello.  I just completed my Stereomour (first amp build).  (2A3 120V) All my resistance readings are in range and all voltages are in range with the following exception:  all points that are spec'ed at "165-220" are reading low by a factor of 10.
Terminal     Voltage         Spec
    2                17            (165 - 220)
   14               18               "
   OA              22               "
   OB              22               "
I appreciate any advice on where to look.
thanks
-sean
« Last Edit: June 30, 2014, 05:21:10 AM by SeanHolcombe »
Reply #1 on: June 30, 2014, 08:11:27 AM
Check the parts on the small board for orientation and correct value.
Reply #2 on: June 30, 2014, 12:36:57 PM
thanks for the reply.  turns out, it was just a lousy volt meter. all readings are good now.
