when I've check resistance I've noticed that T6 and T9 are now showing 0. All other values seems fine.
Did you perform the modification on the headphone jack mentioned on this forum?
Generally, a Crack will smoke when the Speedball is installed if the TIP50 transistors are improperly mounted.
One way to check for this is to put the Speedball back in and run the Crack with just the 12AU7.
On the bigger Speedball board, the TIP50 transistors must have no metal-to-metal contact with the heatsink. If the hardware is not properly installed between each TIP50 and heatsink, you will create a short once the amp warms up.
