Stereomour balance potentiometer
kompakt · 3057
Offline kompakt
on: July 10, 2014, 06:16:24 PM
Hello!
I like to use a balance potentiometer for my Stereomour,but witch value most i take?
Best Regards
Seyed
Reply #1 on: July 11, 2014, 01:17:24 AM
You can add a 100k Ohm balance pot in front of, before, the volume pot.
Be advised, wiring of a true balance control is not as I first thought.  Carefully draw a wiring diagram after you measure how it works with your meter.
The last one I installed took 3 wiring diagrams before I got it right.
Here is the kink, when you fade to the left channel the left channel is not changed, the right channel lowers.  When you fade to the right channel the right channel is not changed the left channel lowers.
Good luck !
« Last Edit: July 11, 2014, 11:42:02 AM by Grainger49 »
Offline kompakt
Reply #2 on: July 11, 2014, 06:33:53 AM
Hello!
Thank you very much
Regards
Seyed
