I wound up going with 2 different (single) probes from Test Products Int'l ("TPI"). A model P250 x100 non-switchable passive probe rated at 1500 v for $45, and a model SP100B switchable 1x/10x passive probe rated at 150/300 v for $40, both from Digi-Key.
I called TPI before deciding to buy these, and mentioned to one of their tech reps that some vendors show TPI's 1x/10x passive probes being rated at 600v. (You can see the same thing on the web with other x10 probes, marketed under different names.) He replied that the 150/300 v values on their website were correct (the same or similar ratings as published by Tektronix, Pomona and others for x10 probes, BTW) and that TPI tries to get retailers to list the correct (lower) working voltage of their probes. He also said that there are only a few manufacturers of oscilloscope probes, and that the difference in price between the passive probes sold under different names is basically a marketing decision.
Now I just have to remember which probe is which before picking [it] up and measuring high voltage.
"Too soon old;
Too late schmart"
The late Mr. Fox, Fox's Deli, Rochester, NY
Mike P.
