DIY Hi-Fi rack
mcandmar · 8278
on: August 11, 2014, 05:23:21 PM
I came across the idea on Head-Fi of building a rack using chopping boards from IKEA. After a quick browse of the catalog i found the perfect size chopping board in 16mm thick Bamboo, the legs are also IKEA items. Total cost for the build was under €50.
Boards used are http://www.ikea.com/ie/en/catalog/products/80233430/ €9.75 each, or $8.
Legs used are http://www.ikea.com/ie/en/catalog/products/60196513/ €5.00 for pack of two.
Double stacking the legs gives 8" clearance which is the perfect height for my S.E.X amp.  Each set of legs comes with two lengths of threaded rod which is used to join the legs together.  The four plastic feet left over can then be cut up to salvage the metal bolts which are used to mount the top shelf.  Only bit of fab work needed was to chisel out the recess's for the bolts on the top shelf and then drill four holes in each panel. The wood finish is exactly how they come so i didnt need to do any treatment to them.
Thought it was worth sharing here as i suspect the Bamboo would compliment a pair of Blumenstein speakers rather nicely ;)
Mark
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fcdn.head-fi.org%2Fb%2Fb7%2Fb7830cd1_Stand.jpeg&hash=b900fa0e8018d1a712c2862617d0d80e05b9022e)
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fcdn.head-fi.org%2Fe%2Fe5%2Fe573ee56_Bolt.jpeg&hash=554c0cb3887578cb156c5e38a6450b342a71c82b)
Reply #1 on: August 11, 2014, 06:43:11 PM
Nice, this may be OT but I have been shopping for a bamboo cutting board.
Offline JamieMcC
Reply #2 on: August 11, 2014, 10:09:01 PM
Super idea Mark and a great job, going to have a go at it myself when next I get off the Island I feel Bamboo enclosure for a Crack might be on the boards as well.
Offline Zimmer64
    • Blog
Reply #3 on: August 12, 2014, 02:56:05 AM
Great idea. Thanks for that.
Reply #4 on: August 12, 2014, 03:14:36 AM
^ nice pun.  With your woodworking skills i'm sure you could knock up a few full range speaker cabinets with the stuff :)
Offline JamieMcC
Reply #5 on: August 12, 2014, 06:27:48 AM
Now there's a thought, I have been planning a trip to Ikea the other half was looking at some of the billy bookcases so will have to take the car over on the ferry its a bit of a rip off at £80 return for the 60 minute trip each way 10 mile :'( ! At least the store is close when you get to the mainland
Shipping stuff is a real hassle at times just yesterday I wanted to order some 22mm glass fibre rod from the factory that makes it cost £10 for a metre shipping to a mainland address is £15 via their courier service to a mainland address which is fine but when I mentioned I was on the Island the shipping cost went to £35 I asked if they would send via regular mail or parcel force as it would be less than £10 but no chance. I found another supplier who was more helpful.
Reply #6 on: August 12, 2014, 06:48:09 AM
Sounds like you need to buy a boat :)    ...dont get me started about shipping prices.  N.Ireland is mainland UK rates, Southern Ireland is x2-x4 times the cost and the only difference is 100miles of motorway and an invisible border!
Offline EarWorm
Reply #7 on: August 12, 2014, 09:08:05 AM
Nice!
 I was inspired to post one of my own DIY racks for the forum after you posted yours but every time I try I get a writable error.
Sony 8FC-69WA AM/FM Digimatic Flip Clock Radio Circa 1971.
1962 RCA Victor 4 Volt Superheterodyne AM Radio With ear Jack & plastic ivory ear piece.   What?
Reply #8 on: August 12, 2014, 09:11:27 AM
Yes, for now you need to use an image hosting service and post a link while we are doing some upgrades to our server.
Offline wullymc
Reply #9 on: August 12, 2014, 10:52:00 AM
Mark beautiful job!  Looks top notch.....I'll order one! ;)
Thanks for the heads up on the boards.
A couple of questions for you:
1.  what did you use to make the holes.  Bamboo is pretty durable.
2.  I am interesting in how you made the hex bolt fit in.
Thanks...Dave
Dave
Project RPM5.1 with 2M Bronze/Graham Slee Era Gold V/Quickie with PJCSS/Paramount 1.1 300B/Woden Valiant
ODAC/Crack/DT880 600ohm
Current Project:  Beepre!!!
Reply #10 on: August 12, 2014, 11:00:07 AM
Holes were just a regular wood drill bit (the ones with a point), for the hex's i just marked around the bolt with a pencil then chiseled it out.  The heads of the bolts are ~2mm thick so you don't have to dig very much out.
Offline JamieMcC
Reply #11 on: August 12, 2014, 12:07:11 PM
I quiet like the look of the recessed bolt heads its a nice feature I'm wondering if I have a bit of a fossick about I might even root out some brass or bronze bolts.
I am guessing t would be easy enough to fit a big head fastener on the underside if you wanted to keep the top clear.
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fwww.whos-who-in-industry.com%2Fuploads%2Fbigheadmarine.jpg&hash=37cb9450a8d6ada60adcd15c7f2ffeca9734d8a7)
Offline wullymc
Reply #12 on: August 12, 2014, 11:13:52 PM
Thanks Mark.
Looks like I'll have another project after my speakers and Paramounts!
Take care....Dave
Dave
Offline Zimmer64
    • Blog
Reply #13 on: August 15, 2014, 08:08:40 PM
Here is my approach. I've built the entire shelf from bamboo, sanded and waxed it. The joints have been made using biscuits and glue and I am using sorbothane feet.
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi1372.photobucket.com%2Falbums%2Fag324%2FMichaelZimmer999%2F34010dcef91148bc01be6e7f2dacd4c3_zpsb60cdcd8.jpg&hash=7e58cc9e545f4508768ae1b132644b942955dba2)
« Last Edit: August 15, 2014, 08:10:19 PM by Zimmer64 »
