Tube Rolling w/Crack
Dr. Toobz · 1597079
0 Members and 7 Guests are viewing this topic.
Offline cddc
Reply #1980 on: June 18, 2019, 07:36:28 PM
One more question:
I am comparing 2 headphones recently. So I am wondering whether it's okay to plug & unplug headphones into my Crack without having to turn it off?
Currently I turned off my Crack before switching headphones, because I was concerned that the metal part on headphone plug would bridge 2 adjacent sections inside the headphone jack on Crack and would possibly short Crack circuits during plugging or unplugging.
Offline Tom-s
Reply #1981 on: June 18, 2019, 07:43:52 PM
There's no problem switching headphones with the amp on.
I always plug in my headphones after the amp has warmed up (essentially the same as changing headphones).
This because i roll a different tube almost every day, and before i had a tube tester (to check for internal shorts) i've seen some spark shows during tube warmup.
Edit: Just make a 4 banana/spade to 4 pin XLR adapter. That's what i use for the AKG K1000 headphone and works just fine for now. But i do see your point about the extra headphone connection.
« Last Edit: June 18, 2019, 07:46:04 PM by Tom-s »
Reply #1982 on: June 19, 2019, 04:59:04 AM
On the other hand, I would love to see Bottlehead to add a headphone jack to their 300B or 2A3 speaker amps if possible.
You can do this with an adapter cable.  This isn't a good idea unless the DC filament upgrade is added to our directly heated amps.
Offline cddc
Reply #1983 on: June 19, 2019, 07:15:33 AM
Greart to hear. Thank you very much, Tom!
That would make switching headphones much easier.
Offline cddc
Reply #1984 on: June 19, 2019, 07:41:41 AM
You are correct, that's why it's hard for users to heavily mod their amps.
I still think it is a good idea to have some official Bottlehead 2A3/300B/845 amps with both headphone and speaker outputs.
Reply #1985 on: June 19, 2019, 09:19:03 AM
Well, we have the SEX amp.  It's significantly quieter than we could make a 2A3/300B/845 amp and it has speaker and headphone outputs.
If we put a hole on the Kaiju plate for a headphone jack, then filled it with a plug for the stock kit, we would end up answering the same technical support question over and over again about why the stock amp is noisy on headphones when builders put the jack in without the DC filament board.  I would also want to make it so that the speakers switch off when headphones are plugged in, and that is a significant amount of work as a retrofit item.  We would then be in the awkward position where our majority of users who use these amps with speakers would be on here asking us why there was a headphone jack.  There are also what 2 or 3 pairs of headphones that could make use of 8W?
We could certainly make an adapter cable with banana plugs on one end and a 4 pin XLR on the other.  Or you could check these out:
https://www.ebay.com/itm/Dyson-Audio-4-pin-XLR-to-Spade-Balanced-Headphone-Cable-Speaker-Tap-Adapter/113437046309?hash=item1a695ff625:g:4jIAAOSwkfxcDXXf
https://www.portentoaudio.it/en/prodotto/adattatore-xlr-4-pin-banana/
http://apuresound.com/v3haec.html
You could also drill a hole in the wood on the Kaiju or Stereomour and install your own headphone jack.
« Last Edit: June 19, 2019, 01:24:44 PM by Paul Birkeland »
Offline cddc
Reply #1986 on: June 19, 2019, 12:11:02 PM
Ahhh...I saw the challenges making a 2A3/300B/845 headphone amp.  :o
Thanks very much for the explanation and alternative solutions, PB!  :)
Offline L0rdGwyn
Reply #1987 on: June 20, 2019, 06:37:21 PM
With the appropriate adapter, what would be the feasibility of using a shared cathode 6N7G/6N7GT tube in the Crack + SB (or Crackatwoa in my case)?  Would it be safe to throw in and give it a whirl despite being incorrectly biased?
https://frank.pocnet.net/sheets/127/6/6N7.pdf
Wish I had the knowledge to say, I am slowly but surely teaching myself.  I can see the plate dissipation is double that of a 6SN7, so it seems that should not be an issue.
Keenan McKnight
Reply #1988 on: June 20, 2019, 06:47:33 PM
You would have to use two 6N7s.  15mA and 80V or so of plate to cathode voltage on a 6N7 will give a grid bias voltage of about +10V, which will cause the grid of the 6N7 to draw significant current.  This grid current will throw the operating point of the circuit off significantly!  This might pass music through, but it will be badly distorted and you'd damage the 6N7 eventually.  You'd also raise the output impedance by about 50%.
Offline L0rdGwyn
Reply #1989 on: June 20, 2019, 07:23:57 PM
Okay, so I am going to take that as a hard NO, ha!  Thanks, PB.  I hope to get to a point where I can make that determination on my own, not a lot of spare time to do so, unfortunately.  But I do know that a positive voltage on the grid is no bueno.
Keenan McKnight
Offline L0rdGwyn
Reply #1990 on: July 13, 2019, 06:23:03 PM
Wish I knew how to determine this on my own, but is there any reason putting a Mullard ECC32 in the stock Crackatwoa would be harmful to the amp or the tube?  I would be using a 6SN7 to 12AU7 adapter.  I typically use 6SN7s but I know the ECC32 is not a direct equivalent.  Thanks!
Keenan McKnight
Offline Tom-s
Reply #1991 on: July 13, 2019, 11:12:31 PM
If my recollection is correct.  With Crack the ECC32 bias will set correctly, with the 475R R1 resistor on the CCS board.
Voltages will be high with the 237R R1 resistor. Plug one in, and measure after 5-10 minutes of warmup.
I'm a happy camper with these tubes. Although i feel money is better saved for a Mainline.
With all this tube rolling. I keep coming back to 12BH7's.
Offline L0rdGwyn
Reply #1992 on: July 14, 2019, 04:23:37 AM
Thanks, Tom, I'll look into it.  I really enjoy the 12BH7 as well.  I recently acquired a pair of Italian Fivre 12BH7 tubes, they sound fantastic.
Keenan McKnight
Offline L0rdGwyn
Reply #1993 on: July 16, 2019, 04:39:06 PM
I'll be buying a Crackatwoa in the not-too-distant future and am thinking about suitable tubes.
When I owned the Crack I went nuts on tube buying - WE421A,  GEC 6AS7G, Amperex 7316 etc. I've learned from my misspent youth and am buying many fewer and much, much cheaper tubes based around a theme: Australian made.
Is anyone aware of an Australian made candidate for the output position?
Hi Toad - saw your post on HF as well.  I have never seen an Australian-made 6080 or 6AS7G, no output tube compatible with the Crack actually.  I have seen some 6SN7s floating around that could be used as inputs.  Unfortunately, what you had before are truly the best!  But prices are only going up and availability going down.  There are of course good sounding outputs for not a whole lot of money, like the Tung Sol 7236 or RCA 6AS7G black plate.  If you can find them, there are some very good Japanese 6AS7G tubes out there for very little money, usually.
Keenan McKnight
Offline cddc
Reply #1994 on: July 16, 2019, 07:15:00 PM
Please ignore...my bad....ECC32 instead of ECC82....I thought you were asking about ECC82 which is an European version of 12AU7.
« Last Edit: July 17, 2019, 12:32:35 PM by cddc »
