Tube Rolling w/Crack
Dr. Toobz · 1597820
0 Members and 13 Guests are viewing this topic.
Online Paul Joppa
Reply #2265 on: February 02, 2021, 06:55:14 AM
It's common to all 6AS7/6080 tubes.
Reply #2266 on: February 02, 2021, 07:11:24 AM
There is a warning about that in the data sheet, including a minimum cathode bias resistance.
It's also worth mentioning that in a Crack with the Speedball, the 6080 isn't able to draw more current than the current sources under the cathode allow.
Reply #2267 on: February 02, 2021, 11:11:41 AM
It strikes me that a failure mode that occurs after just one time running the tube with no visible arcing is likely to be about the tube getting gassy, or having developed a hard short after thermal cycling, or a tube pin connection opening up.
Offline cddc
Reply #2268 on: February 02, 2021, 11:21:08 AM
Interesting, since Doc B. was talking about arcing and shorting, I am now thinking whether the Speedball will protect us from the possible damages from arcing and short (since Speedball will limit the excessive current draw). haha  ;D
Reply #2269 on: February 02, 2021, 01:04:06 PM
If the grid shorts to the plate, the C4S isn't going to help you.
Offline cddc
Reply #2270 on: February 02, 2021, 01:12:51 PM
Thanks PB, then I'll continue to stay away from 5998/421A tubes as they are known to be prone to arcing.  ;D
Offline Welderboy
Reply #2271 on: February 14, 2021, 01:01:50 PM
Sigh, so I have another Thomson 6080WA  failure. Second tube, different vendor, same serial number.
Anything I can troubleshoot or is there something wrong with this batch? I don't have a tube tester unfortunately.
In this case the tube lasted several days, and stopped working after I turned the amp off and swapped out a different input tube. Other tubes work just fine, although I do prefer the sound of these.
Reply #2272 on: February 14, 2021, 01:03:46 PM
There isn't anything you can troubleshoot if the tube is the issue.
Offline Welderboy
Reply #2273 on: February 14, 2021, 01:08:57 PM
So should I assume there's a bad batch of these being sold? Serial # is FSE-8052-FF in case anyone has one from the same batch.
Reply #2274 on: February 14, 2021, 04:06:49 PM
Yes, there are many users positing similar experiences with those tubes from that eBay vendor.
Offline Deluk
Reply #2275 on: February 16, 2021, 01:47:04 AM
My Thomson came from Langrex in the UK and is fine and I like the sound with my 4003. This one is from FSE-8140-FF.
Langrex are only about 60 miles from me.
Reply #2276 on: February 16, 2021, 05:05:51 AM
The note on their site "Do not use this tube in Chinese made headphone amplifier" is starting to make more sense now, i bet a bunch of D******** owners bought them after reading about them on a forum and had a bunch of failures.  "Do not use this tube in amercian kit headphone amplifiers" will be added next  :P
Offline Welderboy
Reply #2277 on: February 16, 2021, 06:15:36 AM
This wasn't from the .tw vendor - these are two different ones.
Reply #2278 on: February 16, 2021, 10:05:12 AM
Sounds like the proper disclaimer is "Do not use this tube, period".
Reply #2279 on: February 17, 2021, 07:16:02 AM
Yeah, I wonder what kind of eruptions would happen in an OTL speaker amp, where there are usually no protections in place.
