Tube Rolling w/Crack
Dr. Toobz · 1622028
Reply #2460 on: December 07, 2024, 04:32:38 AM
Are you meaning testing the terminal on the back of the noval socket while it is running?
The terminal strips in the Crack are numbered and terminals 1 and 5 refers to specific places in the amp where you measure DC voltages.
Offline kylescholten
Reply #2461 on: December 09, 2024, 12:27:09 AM
Hey just wondering what the most loved 12au7 is for my Crack w/ SB. I have a Western Electric 421A for power tube and use HD600s. I've been looking everywhere for Amperex 7316 long plates but no luck, only expensive short plates which I've been told are not nearly as praised? I just heard of the Mullard CV4003 but found conflicting reviews on the musicality of it and don't know which year/plates to look for with it. Please let me know what the most sought after pairings are assuming money is no object. I know its subjective but I like to know the general consensus.
Offline Tom-s
Reply #2462 on: December 11, 2024, 05:34:47 AM
For good sound I don’t recommend the most expensive or rare ones. In my experience these very old long plate D getters have worn cathodes that easily give hissing noises.
For good sound a properly tested normal ecc82 from the Philips Heerlen factory is recommended.
These can be found for cheap. If you pm ill look for you to see what ecc82 I can spare.
Offline Happy Ghost
Reply #2463 on: December 11, 2024, 07:30:04 AM
I like the Brimar 13D5 paired with the TS 5998... Sound is very accurate.. a bit less holographic compared to a good 6SN7 but well worth it..
Atul
Offline DitchTrilogy
Reply #2464 on: January 16, 2025, 10:03:07 PM
Is there a standard grading system or reference for used tubes? I'm seeing grades like the below from some stockists but don't know what it means.
GRADE 1 TESTED 70% PLUS
Reply #2465 on: January 17, 2025, 04:36:34 AM
No, there is no standard grading scale, and what 70 means will depend quite a bit on the particular tester used.
Offline Colonl_Charisma
Reply #2466 on: January 22, 2025, 08:51:04 AM
Does anyone have a recommendation for a modern power tube?
I was astonished to see prices for TS 5998 and TS 6AS7G tubes. When I bought mine a few years ago, they were nowhere near as expensive.
Ross
Fiio K11 R2R --> Bottlehead Crack --> HD600
Offline Happy Ghost
Reply #2467 on: January 22, 2025, 11:59:05 AM
Atul
Reply #2468 on: January 23, 2025, 07:14:40 AM
Very familiar with the SBAF forum. Jeb’s reviews of the tubes are fantastic.
I was thinking more along the lines of a modern tube like PSVANE. For instance, with an adapter, I use their CV181 as my input tube.
I was wondering if there are any modern tubes that people enjoy.
Ross
Reply #2469 on: January 23, 2025, 08:32:01 AM
The old stock tubes are about the same price as what's being offered from China.  There isn't really any comparison between the two... (for now at least)
