Bottlehead Kits
Legacy Kit Products
Foreplay III
Extended Foreplay III with MJE350 Transistor Regulator Board dropping channels
jlharden
26152
Paul Birkeland
Global Moderator
Hero Member
Re: Extended Foreplay III with MJE350 Transistor Regulator Board dropping channels
Reply #15 on:
September 09, 2014, 08:57:35 AM
Is the nature of the noise added by the Foreplay hum or tube rush?
jlharden
Jr. Member
Reply #16 on:
September 09, 2014, 10:19:28 AM
Probably more tube rush component than hum.
Doc B.
Administrator
Hero Member
Reply #17 on:
September 09, 2014, 11:09:54 AM
If you can, turn down the each of the attenuators on your crossover 3 or 6dB, so that you maintain the proper balance between frequncy bands. Then you can turn the preamp volume up 3 or 6dB and that will improve the signal to noise ratio by the same amount.
jlharden
Jr. Member
Reply #18 on:
September 09, 2014, 01:48:50 PM
I will work with the gain structure. Thanks Doc!
Bottlehead Kits
Legacy Kit Products
Foreplay III
