Crack voltage issues / LEDs not lit
Claudius · 6427
Reply #15 on: September 12, 2014, 05:16:07 AM
Alright, you can actually listen to the amp like that.
The non-glowing LED probably got broken or melted in the build, and will need to be replaced.  You can e-mail replacementparts(aht)bottlehead(doht)com
Offline Claudius
Reply #16 on: September 12, 2014, 05:21:40 AM
Paul--  Thanks for all your help!  I'll request a replacement LED.
Offline Claudius
Reply #17 on: September 12, 2014, 06:21:21 AM
I just plugged in my HD650s and the Crack sounds pretty good!  Is it going to sound any different when I remove the jumper and replace the LED?
Reply #18 on: September 12, 2014, 08:42:52 AM
Probably not. In hypothetical terms, a shared cathode connection can lead to crosstalk, but the dynamic impedance of that particular red led is so low that this isn't realistically a problem.
Offline Claudius
Reply #19 on: September 12, 2014, 08:53:48 AM
Thanks, that doesn't surprise me, given how good it sounds in it's current state.
Offline sparggy
Reply #20 on: September 13, 2014, 11:14:23 PM
Hey guys
Thought I would comment here as I have a similar issue. I have manage to completely melt one of the LED lights. will it still work without this or should I just order a replacement ?
Reply #21 on: September 14, 2014, 05:57:10 AM
Replacing it is best even if the voltages still read correct. If the voltages are not correct you must replace it for sure. You can order some replacements at [email protected].
