Bottlehead Kits
Crack
speedball - transister heat thermal pads
sparggy
2184
sparggy
Jr. Member
September 12, 2014, 04:38:57 PM
Hi Guys
I made a stupid mistake and when opening the packed for the transister mounting kit i cut through the thermal heatpad. I was wondering, I have thermal paste that I used to mount my CPU heatsink, could I use this instead of the pad ?
MrPotatoSalad
Full Member
Re: speedball - transister heat thermal pads
Reply #1 on:
September 12, 2014, 04:48:30 PM
No, you want there to be a contact barrier between the TIP50 and heatsink. I believe the thermal pad is just a high heat plastic.
sparggy
Jr. Member
Reply #2 on:
September 12, 2014, 04:57:45 PM
I have managed to salvage the pad so might be ok
Global Moderator
Hero Member
Reply #3 on:
September 15, 2014, 12:07:43 PM
The pad provides heat conduction and electrical insulation. Both are important! I would recommend getting a replacement (find the replacement parts email link) - I worry the break in the pad could accumulate dust or oils from the air and eventually allow a short to the heat sink. That usually produces smoke and damages other parts.
sparggy
Jr. Member
Reply #4 on:
September 20, 2014, 04:41:00 AM
Thanks Paul.
Yeah did not really feel comfortable with it the way it is and I damaged some LED lights. So I have emailed Queen regarding getting spares and will wait until then to carry on. Will shelve the project until I can proceed safely
Bottlehead Kits
Crack
