SEX tubes
i luvmusic 2 · 28279
Reply #15 on: October 23, 2014, 12:33:01 PM
Use ones that you didn't pay much for...
Offline i luvmusic 2
Reply #16 on: October 23, 2014, 01:07:04 PM
OK THANK YOU!
I will be using the 6H8C for now to see how it goes.
« Last Edit: October 23, 2014, 01:11:08 PM by i luvmusic 2 »
Offline JamieMcC
Reply #17 on: October 23, 2014, 01:20:06 PM
OK THANK YOU!
Make sure to let us know how you get on the Russian 6h8c are inexpensive enough to be regularly disposable.
Reply #18 on: October 23, 2014, 01:36:25 PM
 I don't mean they are inexpensive/disposable,It just happened that i paid $3 a piece compare to my other 6SN7's .
I hoped i did not offend anyone.if i did PARDON ME...
BTW You guys should give it a try it does work and sound nice too.
Reply #19 on: October 23, 2014, 02:11:56 PM
I can never tell if PJ is being serious or just trolling us (https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fwww.cr-x.org%2Fgif%2Fsuspect.gif&hash=f0cf7566a00a8343a1f741a9a520c9f82a7fb71b)
6H8C is basically a 6SN7GT and limited to ~300v plate voltage so it may not be suitable.
Reply #20 on: October 23, 2014, 02:16:35 PM
So far still working no unusual things happening i will run it for a little longer and see.
Reply #21 on: October 24, 2014, 11:42:05 AM
So far i run the 6SN7 on the SEX for 6 hrs last night and no issue.I will continue to use these tube until i see/hear something strange.
Reply #22 on: October 24, 2014, 12:09:11 PM
If we assume that this modification drastically cuts down the life of a 6SN7, say by 50%, then you should run the amp for 5,000 hours and see what happens.  (Not 6)
Offline Natural Sound
Reply #23 on: October 24, 2014, 12:42:29 PM
Not sure why anyone would want to do that to a perfectly good 6SN7. ???
Online Paul Joppa
Reply #24 on: October 24, 2014, 06:45:22 PM
Haha - "smoke 'em if you got 'em"
How does the sound compare?
Reply #25 on: October 25, 2014, 01:24:32 AM
  I'am not good at describing sound but i will try,The 6H8C sounds more relaxing than the 6DN7 a little less Bass and smoother treble.
To my ears there are times that the 6DN7 can be harsh on my ears but so far i did not experienced these with the 6H8C.
  IMO when it comes to music/audio gear it's most likely a personal taste,Sounds that is good to my ears might not for others it's like one of those cable/capacitor debates but lets not go there.
« Last Edit: October 25, 2014, 01:33:34 AM by i luvmusic 2 »
Reply #26 on: October 25, 2014, 05:15:58 AM
   .   .   .    IMO when it comes to music/audio gear it's most likely a personal taste, Sounds that is good to my ears might not for others it's like one of those cable/capacitor debates but lets not go there.
So true and you are the only one that matters in this.
Online Paul Joppa
Reply #27 on: October 27, 2014, 07:15:56 PM
So I fired up an old spreadsheet and looked more closely at the 6SN7-GTB. It should work just fine, and within spec. Output is about 3/4 watts, damping factor 1.0.
A speaker with a very low QT could work really well with the low damping factor; for example an FE-206E Fostex in a 1 cubic foot box tuned to 50Hz or a bit lower. Try a 2.5-inch ID tube 4" long. Parts Express has ready-made 1.0 CF boxes.
Reply #28 on: October 28, 2014, 09:45:02 AM
THANK YOU For the INFO!
Offline FraGGleR
Reply #29 on: November 06, 2014, 11:40:47 AM
Late to the conversation, but thetubecenter.com has 6DN7s and will match them if you want.  I got a pair of GE 6DN7s matched that got rid of the channel imbalance I had with the stock tubes.  http://www.thetubecenter.com/vacuumtubes_tubelist_tubes_6d4-6jz8.html
Resonessence Concero -> Bottlehead S.E.X. 2.1 -> HD800
