If a fella wanted to build with MQ iron...
marantzfan · 3431
Offline marantzfan
on: September 19, 2014, 05:35:29 PM
...is there any option to order the paramount kit without the outputs and chokes?
BeePre, Paramounts 1.1, Eros, Thorens TD-124/AudioMods Tonearm/Ortofon 2M Black, IFI Micro Idsd, HQPlayer,  Altec 604-8G Duplex/620 Cabinets/Markwart Crossovers
S.E.X. 2.1, AKG K701
Offline Alonzo
Reply #1 on: September 19, 2014, 05:47:14 PM
Nah, your missing half the fun.  You build with MQ iron and take the (really good) left over iron and the just learned knowledge from the kit and build a separate tweeter amp for your system.  ;D
Alonzo
Offline johnsonad
Reply #2 on: September 20, 2014, 06:30:24 AM
The chokes you can moved to the power supply making it a CLC if your heart is set on MQ iron. I would listen to it in stock form first as you won't know what you missed. There is a difference between the iron but it's not a large one. You will find a greater change in sound rolling PF caps and tubes with iron in third.
