Terminal 13 [solved]
BetterLate · 2073
Offline BetterLate
on: September 20, 2014, 01:37:53 PM
Terminal 13 reading incorrect - supposed to slowly climb to 270K, instead starts at 5-6 Meg and slowly falls to about 500K then resets and starts falling again. Any help would be most appreciated. Thank you!
« Last Edit: September 24, 2014, 05:12:56 PM by Caucasian Blackplate »
Reply #1 on: September 20, 2014, 03:35:10 PM
Different meters will read it differently. You mostly need to make sure you're not reading 0Ω. If this is the only fault found in the resistance checks, you are ready to do voltage tesing.
Offline BetterLate
Reply #2 on: September 20, 2014, 04:35:35 PM
woohoo, that is fabulous news!  Voltage testing here I come.
Thank you for the help.
Offline BetterLate
Reply #3 on: September 20, 2014, 06:20:22 PM
It works!
Thank you again for the encouragement/help.
All testing completed......turned it on......it works!!!!!
Wonderful!  First DIY, and what a sense of accomplishment! I would never have started this without all the help postings I read before I started. Thank you to all Bottlehead addicts for being the wonderful supportive community you are.
I'm sure it won't be long before I start checking the mail for the Speedball add - on.
Peace.
