Speedball product page
JamieMcC · 2456
Offline JamieMcC
on: September 25, 2014, 06:09:46 AM
I noticed the Speedball product page needs tweaking some text is showing which looks like it should be hidden located below the product picture.
"This is the name of the button 3. After
is the section between the two lines under the tabs, change any text that is in between span brackets i.e. TYPE HERE the span classes change the color and size of the text relatively “undertabog” is orange, “undertabwht” is white, “undertabylw” is yellow. Do not delete brackets EVER, and to add more than one space field add:   To make bullet points use • These are html code for special charachters. Always close tags with a slash like this: --> "
Offline Natural Sound
Reply #1 on: September 25, 2014, 06:37:26 AM
I noticed that on the SEX page the other day. I suspect there are more.
Reply #2 on: September 25, 2014, 06:51:52 AM
We recently asked our web guy about changing where it says "Specs" to "More" since the "Specs" section is where most of the info is, but by calling it that, it sounds like it's just some S/N measurements and stuff. My guess is he started playing with the style sheet and accidentally un-commented something.
Reply #3 on: September 25, 2014, 08:03:23 AM
Might i suggest you separate the Technical info and specs from the Impressions into separate tabs.
For example the Paramount and Stereomour pages are nicely laid out, good underside photo with the techie info and specs clearly laid out while keeping the "Impressions" separated into a section below. The S.E.X. and Crack pages however are a bit of a hodge podge with no consistency between them.  Basically use the same template for all products.
And just to be picky, the Mainline page is missing an underside photo, and a big high res photos of the amps wouldn't hurt either. i.e. When you open a product page and click on the image of the amp it opens the same small image in a window, that should really be a full screen image.
Please take the above as constructive criticism.  I'm more of a show me some pics and technical specs kind of guy and couldn't care less what somebody on HeadFi thinks :)
Reply #4 on: September 25, 2014, 09:05:23 AM
Our man in Arizona cleared it up. It was quite possibly my fault. If someone can find a way to blame Peebs, I'm all ears...
Reply #5 on: September 25, 2014, 11:05:54 AM
You'll note that I have tactfully declined access to such things (for now).
Reply #6 on: September 25, 2014, 11:07:40 AM
When did I ever worry about having a reason in order to blame you for something?
