Foreplay 1 One channel out.
guymsn · 5096
Offline guymsn
on: November 03, 2014, 11:11:46 AM
After a few years of storage my foreplay is only working on one side. tried swapping tubes and no luck. where should I start? Thanks for the help.
Reply #1 on: November 03, 2014, 11:23:21 AM
The first thing to do is check resistances against the manual.  If that passes go on to the voltage measurements.
Post only those that are +/- 15% out of spec.  Also post the expected measurement.
Offline guymsn
Reply #2 on: November 04, 2014, 02:12:14 AM
A quick check on the internet and I couldn't find the manual or test pages.  Our home was wiped out in hurricane sandy with all my paper work thats why the foreplay hasn't been used. Where could I find that page? Thank you again for your help. This was a purely stock build with the gold rya upgrade and recomended dayton output caps. Regards
Reply #3 on: November 06, 2014, 10:59:26 AM
Just the voltages on the 9 pin sockets will be good enough.  Pins 1, 2, 3, 6, 7, and 8 on each 9 pin socket will give an overall indication of operation.
