Bottlehead Kits
Legacy Kit Products
Paramount
Paramount voltage concerns **SOLVED!!**
wullymc
16119
3
Grainger49
Hero Member
Re: Paramount voltage concerns
Reply #30 on:
November 11, 2014, 03:16:06 PM
Dave,
When you check continuity from the newly installed boards to the terminals or tube pins try checking from a component lead that is attached to the input/output/ground solder tab to the metal of the terminal or tube pin. Don't check from solder to solder. That can give you a false sense of security with the solder joints.
I have been bit in the butt by just this. So now I "ring out" from a component to component.
Good luck!
wullymc
Sr. Member
Re: Paramount voltage concerns **SOLVED!!**
Reply #31 on:
November 12, 2014, 04:15:26 PM
Thanks to everyone that contributed to this thread.
I am very happy to report that everything is working now! I have about 3 hours on both amps and everything is great. I had a problem with a FFFFFFF sound when I turned on the left one but that disappeared after 3 turn ons. I don't know if it was just something that needed to burn in a little bit? I don't know.
Anyway, thanks again for your patience with me! I am so happy!
Take care. Wishing everyone well.
Dave
Dave
Project RPM5.1 with 2M Bronze/Graham Slee Era Gold V/Quickie with PJCSS/Paramount 1.1 300B/Woden Valiant
ODAC/Crack/DT880 600ohm
Current Project: Beepre!!!
Paul Birkeland
Global Moderator
Hero Member
Reply #32 on:
November 14, 2014, 07:24:29 AM
There are some warm up noises with the Paramount, which shouldn't be of concern. There will be a little rustling usually, and actually a funny chirp that happens when the 431 regulator begins to operate.
3
Bottlehead Kits
Legacy Kit Products
Paramount
