Maximum Input Voltage
super_stewie · 4203
Offline junkers
Reply #15 on: April 04, 2016, 05:38:56 AM
What DAC do you have that puts out that kind of offset?  You may see a specification that is "Output voltage - 2V", which is the AC signal coming out of the DAC.
There's enough directly coupled solid state gear floating around that this is generally considered a very poor, irresponsible choice that will lead to speaker/headphone damage.
The DAC is sorta DIY, hence the poor output voltage. Just wanted to see what sorts of designs would work. Thanks for looking out though!
Reply #16 on: April 13, 2016, 11:46:24 AM
Ah, well, you should certainly consider a pair of coupling capacitors at the output of your DAC.
