Bottlehead Kits
Crack
Speedball upgrade voltage problem
BetterLate
1904
BetterLate
Newbie
November 08, 2014, 11:19:45 AM
Terminal 14 voltage is 190, should be 0
Terminal 15 voltage is 0, should be 185
I did the crack mod on page 19: "REVISION 5/6/10:
Making this wire 3†long and
connecting it to Terminal 14U
instead of terminal 22L may
yield more quiet operation."
Crack was working fine before modification; haven't completed voltage checks, so don't know current operation.
Can I continue with these two terminal voltages reversed?
Thanks for the help!
Paul Birkeland
Global Moderator
Hero Member
Re: Speedball upgrade voltage problem
Reply #1 on:
November 08, 2014, 05:16:18 PM
There was an old version of the manual that had some voltages shifted.
In reality, if you have the correct voltages at terminals 1, 2, 3, 4, 5, 6, 7, 9, and 10, you're good to go.
Bottlehead Kits
Crack
