line level switch box - calling the smart folks in the room
Cleet Torres · 2185
Offline Cleet Torres
 Hi
I want to build a little passive line level switch box with 3 inputs and 3 outputs, all single ended RCA. So far so good. But I want the outputs to be either independently driven or in multiples.
IOW. For the three sets of output RCA's, call them outputs a, b and c. I want to be able to drive 1.) output a only, 2.) output b only, 3.) output c only, 4.) outputs a and b at the same time, 5.) outputs b and c at the same time, 6.) outputs a and c at the same time, and finally 7.) all three outputs together.
I would like input from one source at a time only.
I suspect smart folks will know how to wire the inputs and outputs in such a way that I can achieve this with two rotary switches only. I want to keep the switchbox as simple as possible and keep as few switches in the signal path.
My head just doesn't want to assist in solving the logic - all them Jim Beams I guess? :P
Regards
Cleet
Offline btrancho
    • Trancho Photography
Reply #1 on: December 06, 2014, 07:12:42 AM
Wouldn't it be enough to simply put a toggle switch on each output RCA, having all wired to play at each selection of the input but being able to turn off/on each output RCA as desired?
Bob Trancho
Reply #2 on: December 06, 2014, 11:03:09 AM
My word Bob, yes, that sounds like a great idea. I'm too embarrassed to tell you how long I have been pondering an eloquent way of doing a switchbox like this.  :-[
Thank you so much and excuse me I need to go have more than a few Jim Beams to wash away my embarrassment.
Regards
Cleet
Offline btrancho
Reply #3 on: December 06, 2014, 11:45:12 AM
We all often start looking at problems from the most complex angles..  That's why forums like this one are so great.
Now I'll go for a Kings County Bourbon or two to to reward myself.
Bob Trancho
