Klots · 8152
I think you might have the grounding jumper issue as described elsewhere in this thread.
You need to return the circuit to the state it was in before the problem started. See if the problem is gone. Then repeat the change you made. If the problem comes back you know that there is some issue with the new part.
Yesterday I got my E80CC tube also, and my crack produces the same buzz with E80CC and 12AU7. Today I will measure resistance and voltages and post them here. Maybe something comes out of them. You also have caps upgraded or just buzzing with E80CC?
changed all caps back and now only B4 is 62V and B6 is 84V...all other pins are great, but...still the buzz on 0 vol.
Have you a different input tube to try as I seem to recall having some similar discrepancies in my voltage checks which turned out to be due to the 12au7 input tube. After I swapped it for a different one and the voltages measured within a couple of percent of those in the manual .
Maybe the off voltages from the 12au7 effect the operation of the 5998 resulting in the noise? Just thinking out loud and not really knowing what I'm talking about but hey that's how you find stuff out
