time for a cap upgrade!
aragorn723 · 1965
Offline aragorn723
on: December 22, 2014, 02:40:52 AM
Hi,
Just got notification that my K75-10 russian capacitors will be here today!  Can't wait to try the next upgrade in the Quickie as it has been quite a while.  Is there a way to burn them in without using up battery power?  Thanks,
Dave
Reply #1 on: December 22, 2014, 04:12:17 AM
Dave,
You can put them across the speaker outputs of an amplifier and play some dynamic music on repeat for 3-4 days.  Don't play too loud, don't have the speakers hooked up at the same time.
This puts higher voltage than you will see in the Quickie across them and gives 90% of break in.
I like these caps.  I have bought several "lots" of them over the last 12 years.
« Last Edit: December 22, 2014, 07:45:18 AM by Grainger49 »
Offline corndog71
Reply #2 on: December 22, 2014, 06:10:17 AM
I don't think the K75's need a lot of break in.  They're a little warm-sounding at first but tend to even out after a short while.  Maybe 50 hours.  Great caps!
Rob
Reply #3 on: December 22, 2014, 06:12:45 AM
How big are the caps? A 2.2uF cap will have a reactance of around 8 Ohms at 10kHz, dropping to around 4 Ohms at 20kHz.  This is probably just perfect to sit at the output of an amp, but breaking in a 22uF cap in this manner would be a rough load for most amps (An 8 Ohm resistor in series would fix that).
Offline aragorn723
Reply #4 on: December 22, 2014, 07:04:15 AM
The caps are 2.2 uf.  Grainger, how would I do the burn-in?  Plug a cd player direct into the amp, then have a cap across each set of amplifier outputs?  Thanks,
Dave
