Bottlehead Kits
Legacy Kit Products
Paramount
Setting plate voltage - do you need to reset it after replacing tubes
wullymc
3388
wullymc
Sr. Member
January 01, 2015, 03:17:49 AM
Hi there,
First of all happy new year. All the best for 2015!
I am going to replace the tubes in my Paramount and just have a question regarding the plate voltage.
Do you need to adjust this if you just swap the 300B? My thinking is no.
Do you need to adjust this if you swap the 5670 tube? My thinking is yes.
Also, does anyone have any comments on Pearl CryoValves? I was thinking of picking up a couple from Partsconnexion.
Thanks for your help!
Dave
Dave
Project RPM5.1 with 2M Bronze/Graham Slee Era Gold V/Quickie with PJCSS/Paramount 1.1 300B/Woden Valiant
ODAC/Crack/DT880 600ohm
Current Project: Beepre!!!
Paul Birkeland
Global Moderator
Hero Member
Re: Setting plate voltage - do you need to reset it after replacing tubes
Reply #1 on:
January 01, 2015, 08:08:06 AM
Hello Dave,
In the 300B amp, the 5670 plate voltage isn't as critical as in the 2A3 circuit. Having said that, since you can perform the adjustment, I would recommend doing so when you swap out driver tubes.
wullymc
Sr. Member
Reply #2 on:
January 01, 2015, 08:54:54 AM
Thanks so much Paul for the quick reply.
Have a great year ahead. Take care...Dave
Dave
Bottlehead Kits
Legacy Kit Products
Paramount
