Issue with Crack Voltage [solved]
lwhitit · 11567
Reply #15 on: January 16, 2015, 01:39:04 PM
When checking the voltage touching the middle and either end leg causes the leds to light up bright. What should I try next?
That would tend to suggest a flaky solder joint on the MJE-350.
Do a slow 3 second count once your tip is on each solder joint, that ought to give the solder enough time to work into the through hole and make a good connection.
Offline lwhitit
Reply #16 on: January 16, 2015, 01:41:19 PM
As always thanks for the reply PB! I tried this last night but I will give it another whirl tonight and report back the results.
Offline lwhitit
Reply #17 on: January 16, 2015, 07:09:00 PM
No Change. Should I try swapping some parts or moving things around?
Offline Strikkflypilot
  • Shellac fiddler
Reply #18 on: January 16, 2015, 07:19:18 PM
Any chance of a closeup?
When I had this problem, reheating that joint took a couple of tries because rosin had solidified between the pad and leg, what helped me was desoldering with a braid before redoing the joint.
Home system:
DAC: Schiit Gumby
Amp: Bottlehead Mainline
Phones: HD800S
Office:
Sources: Iphone/ Ipod
DAC: Dragonfly Red+Jtrbug
Phones: HD580,HD600 grilles
Offline lwhitit
Reply #19 on: January 16, 2015, 07:23:40 PM
Best I can do. Thanks for the quick reply.
Reply #20 on: January 17, 2015, 09:39:59 AM
On your last photo, have a look at the solder joints on R2.  One of them looks very inadequately heated.
Offline lwhitit
Reply #21 on: January 21, 2015, 08:57:27 PM
I removed the old solder and cleaned everything up again but still no change. Not sure what else to do.
Reply #22 on: January 27, 2015, 08:11:22 AM
You might want to try running the amp with no 6080 and with the large Speedball board removed.  This will isolate the 12AU7 and the small PC boards that feed it, and may bring your voltages at T1 and T5 back into check.
Offline lwhitit
Reply #23 on: January 27, 2015, 12:17:10 PM
Thanks for the response
Just to confirm I remove the 6080 and disconnect the large SB board (with the heatsinks). After that do I leave the originally connecting wire unconnected or how should I orientate everything after removing the big board?
Reply #24 on: January 27, 2015, 03:46:16 PM
Leave the wires that went to the big board poking up in the air, away from anything else.
Offline lwhitit
Reply #25 on: February 04, 2015, 07:14:34 PM
Real life got in the way but I was finally able to test this out. Removing all wires to the middle pcb did regulate the voltage for #1 (75) but #5 jumped all the way to 211.
Reply #26 on: February 04, 2015, 07:24:19 PM
Now swap the small boards.  This will either isolate the issue to one of the C4S boards, or half the circuit under them.
Offline lwhitit
Reply #27 on: February 04, 2015, 07:49:17 PM
Swapping the boards: B is the bad one 211 on #1. A jumped up a bit when I swapped it 83 on #5.
Reply #28 on: February 05, 2015, 07:23:58 AM
Try again to reheat the center leg on the MJE-350 on the bad board.  Also be 100% sure that you have the correct R1 resistor installed, as swapping one of the big board R1 resistors onto a small board will leave you with high plate voltage.
Offline lwhitit
Reply #29 on: February 09, 2015, 08:37:33 PM
You were right I swapped the resistors :o I triple checked this thing but sure enough. I now have 80 on #1 (bad one) and 82 on #2.
Putting it back together and powering up now I am back to where i started but with different readings. I am going to get there.
3/4 LEDS on big board lit other 4 leds are lit but very low.
Terminal Voltage
1 75-90 (67)
2 170 (76)
3 0 (0)
4 170 (75)
5 75-90 (36)
6 0
7 100 (66)
8 0
9 100 (33)
10 0
11 0
12 0
13 170 (75)
14 0
15 185 (129)
20 0
21 206 (189)
So the issue is now on the big board?
« Last Edit: February 09, 2015, 09:03:55 PM by lwhitit »
