Issue with Crack Voltage [solved]
lwhitit · 8346
Reply #30 on: February 10, 2015, 07:03:40 AM
Yes, I bet if you pull the 6080, those voltages will pop up.
Are your TIP50's properly isolated from the heatsink with the supplied hardware?
Offline lwhitit
Reply #31 on: February 10, 2015, 07:20:16 AM
I will check it out tonight to test. I reviewed the instructions and I did place the thermal pad (was different from instruction pic, clearish plastic looking sheet) in between the heatsinks and the tip50's. Also the fibre washer was used for each.
Offline lwhitit
Reply #32 on: February 10, 2015, 08:13:50 PM
Terminal Voltage (6080 removed) Plus pictures of both TIP50's and heatsinks.
1 75-90 (79)
2 170 (222)
3 0 (0)
4 170 (222)
5 75-90 (81)
6 0
7 100 (1)
8 0
9 100 (0)
10 0
11 0
12 0
13 170 (222)
14 0
15 185 (228)
20 0
21 206 (233)
Reply #33 on: February 11, 2015, 02:08:08 PM
Yeah, that indicates that there's either a short on the board, or the TIP50's are touching the heatsinks.
Offline lwhitit
Reply #34 on: February 11, 2015, 03:35:55 PM
I am not sure what to do next. Are the pics good enough to confirm if I did it correctly? If so what should I start to check on the board.
Reply #35 on: February 11, 2015, 04:31:19 PM
Check the resistance between the metal tab of each TIP-50 and the screw.
Offline lwhitit
Reply #36 on: February 11, 2015, 09:43:18 PM
I checked it out and both look good. I get a 1 (no reading) when I check both metal tabs (silver) of the tip-50's and the connected screws.
Reply #37 on: February 12, 2015, 05:31:43 AM
Well, we know that the 6080 is functional, as you did pass the voltage tests with the stock circuit.  Now that you have the small PC boards working, that only leaves issues with the large PC board.  I would suspect that some adjacent pins are soldered together, causing the short that is dragging your voltages down.
Offline lwhitit
Reply #38 on: February 12, 2015, 06:20:40 AM
Ok that gives me an idea what to look for. I will check out my soldiering on the big board and report back.
Offline lwhitit
Reply #39 on: February 12, 2015, 09:57:45 PM
I took it apart again and redid all the connections on the big board. Powered it up and all 4 leds were lit! I can finally leave you alone. Its up and operational and everything sounds good so far.
Thanks again PB
