Any advantage to replacing PS resistors with chokes?
Tubejack · 19986
Offline grufti
Reply #15 on: March 29, 2012, 07:54:01 AM
I don't know the answer to that one. PSUD2 is a popular program for being so specialized. I suspect that you can find some info at duncanamps and much more by doing google searches.
Other than that you might just start your own journey: [1] why do I want to change the power supply? possible answers to reduce noise, to reduce distortion [2] how is the ps built up right now? all components with necessary values and schematic [3] how does this ps perform in the psud2 simulation? voltages, voltage variation, voltage at startup in various components, currents dto [4] where does the choke fit in and what happens? with all of those steps it helps to check frequently, if the psud2 simulation matches measured performance just to make sure you are using the correct values for components and the correct circuit layout.
It's worthwhile, if you care. If you don't, you might want to ask for advice how to change your power supply rather than swap parts on a whim. The Bottlehead power supplies are pretty good to begin with and you don't want to spend money and effort making them worse.
I downloaded the PSUD2 software and played with it a little, but not sure what I'm looking at. Is there a site with information on interpreting the data?
Offline BNAL
Reply #16 on: March 31, 2012, 03:49:39 AM
Well I installed the second Triad choke in the power supply. Damn this amp is getting heavy.
I like the results. There seems, to my ears, to be improved clarity and more definition to the music. Everything seems to have very good impact with and seperation. I was going to replace the electrolytics with film, but think I will save my money for now.
This is such a fun amp that only cost $300 with speedball and I only spent about $60 in parts upgrades, not including tubes. I can't imagine finding a better deal.
I still have a Bottlehead power cord on the way.
Brad Nalitt
Iron Upgraded S.E.X. Amp 2.0
Foreplay III
Quickie w/PJCCS
Eros Phono
Offline Dr. Toobz
Reply #17 on: March 31, 2012, 04:21:23 AM
Am I correct in that at least electrically, the benefit of a choke in the PS is twofold: a) greater isolation of supply-related noise from the output signal, and b) the ability of the inductor to hold electrons in its magnetic field, which would indicate the potential for reserve capacity when the amp "asks" for more juice during a loud transient? The Triad choke is cheap, so I might try one out as well. I have to say, though, the Crack is already near perfection as-is, between the Speedball, good tubes (including the E80cc in the driver's seat) and film capacitors in the output position (previously, large-value electrolytics bypassed with small films - but I've recently given up on using AKG's with this amp and will just stick to Senns).
Reply #18 on: March 31, 2012, 04:22:44 AM
Well, Brad, your ears are the only two that have to be happy.
Bottlehead is not adverse to chokes in the power supply.  It was a frequent, and suggested upgrade for the FP 1 and 2.  The Eros PS PCB has spare solder pads for a choke.  In that case you have to remove the resistor, of course.
Some of the finest scratch built amps I have ever heard had enough iron to sink a small ship.
The function is several fold.  The choke not only drops a little voltage and slows the charging of the next cap creating smoother DC like the resistor.  A choke resists rapid current changes through it.
This feature of chokes slows the inrush current at startup.  And it feeds back some current when you turn it off.  That last bit doesn't harm anything.  It just slows the drain of the B+ a little bit.
Chokes pose a high impedance to high frequencies and low impedance to low frequencies.  You can see why they are used in crossovers.  But in a power supply this characteristic blocks noises that are high frequencies while passing anything DC to low frequency (120 Hz rectified, and lumpy DC).  This high frequency noise will pass right through a diode and resistor.
And some day I will sit and do some serious work with PSUD.  BTW, it is standard fare for all electrical engineers today, not when I was in school.  I was a recruiter at Georgia Tech and UT for Kimberly-Clark.  Every applicant had PSUD on their list of skills.
Offline grufti
Reply #19 on: March 31, 2012, 08:25:37 AM
Chokes are great in power supplies. I never argued against the choke in Brad's amp by the way, but you don't want to increase the size of the capacitors in front of the choke. On the contrary, compared to an RC arrangement you really want smaller capacitors in front of the LC. It has multiple benefits. You can still increase the capactor value towards the end of your filter chain.
Offline earwaxxer
Reply #20 on: March 31, 2012, 11:05:35 AM
Hi Dr. Toobz - I know its a bit off topic, but you mentioned switching out the electrolytics for films - curious as to what size films you used and what effect it had. Thanks much.
Eric
Offline Noskipallwd
Reply #21 on: March 31, 2012, 07:03:23 PM
Shortly after building the Crack I replaced the last 270ohm resistor in the PS with the Triad choke. There was an improvement, not earth shaking though. It brightened up the top end most notably, and considering I listen with HD 650s was a welcome change. Replaced the last 220uf cap in the PS with a Mundorf mkp, not sure that was worth the expense, replacing the 100uf output lytics with Mundorf film caps was a definite improvement. The Triad choke is less than 20 bucks, so imo it's a no brainer.
Cheers,
Shawn
Shawn Prigmore
Offline Dr. Toobz
Reply #22 on: June 20, 2012, 05:57:30 AM
I have to order some things from Mouser and Angela Instruments for my Stereomour kit before I move to the wiring stage, so I'm still debating whether I should pick up the Triad choke while I'm at it and replace the first PS resistor in the Crack. Problem is, I don't see how this is going to be worth it - the amp is now absolutely dead silent with the 6CG7, shielded heater wiring, grounded center shield (pin 9), upgraded, non-metallic pot (Alps), and this is even with the pot wide open. It's so quiet that I have to look over at it to know if it is on. Plus, I have the Speedball boards, which no doubt contribute to the quiet, effortless sound. So, what would the choke really accomplish at this point?
Offline jimiclow
Reply #23 on: June 20, 2012, 05:03:19 PM
You're right. I'm not even going to do a speedball upgrade on mine (for now).
BTW, what upgrades/parts are you trying to put in your Stereomour? I'm expecting a Stereomour next month. I already have a Mundorf silver oil parafeed and coupling caps.
Good luck on your build. I think a choke is more useful on the Stereomour but the problem is where to install them.
SEX 2.1- Alps, Mundorf
Stock Crack
Schiit Asgard, Schiit Lyr
Technics SL1200mkII
Woo WA-6
Offline Dr. Toobz
Reply #24 on: June 21, 2012, 12:11:04 PM
Nothing fancy - just a better potentiometer, different output capacitors, and two stereo 1/4" jacks, to allow me to squeeze a sub or headphone amp output in there without losing the third input or drilling extra holes in the plate. I also ordered a red nut for one of the jacks, to differentiate the output jack from input.
Since the parts I ordered weighed all of four or five ounces and made the shipping cost kind of ridiculous for such a small parcel, I went ahead and grabbed a Triad choke while I was at it. I will report back any improvements to the Crack once it's installed.
Offline jimiclow
Reply #25 on: June 21, 2012, 03:12:00 PM
Thank you. Please do report back with your impressions.
Stock Crack
Technics SL1200mkII
Woo WA-6
Offline jrihs
Reply #26 on: June 21, 2012, 08:23:48 PM
HI, Does it matter which wire goes to which terminal? I'm thinking no but...
John Rihs
Reply #27 on: June 22, 2012, 12:35:17 AM
John,
I think I have this right, if it has a dot, the dot goes to the higher voltage.
Offline Noskipallwd
Reply #28 on: June 22, 2012, 07:51:14 PM
Sorry, I just noticed your post, Grainger is right about the dot. Unfortunately I can't remember if it had one, I will take a look in the morning when I get home.
Cheers,
Shawn
Shawn Prigmore
Reply #29 on: June 23, 2012, 01:33:55 AM
Crap! Somewhere someone posted a way to determine which lead should be dotted and I didn't bookmark it.
