Replacement tube works, however, misaligned and smoky smell but ...[Solved]
TheCoolDoc · 6798
Offline TheCoolDoc
Thanks for the replacement tube Bottlehead. Everything is working well now.
I just had a few questions:
1. Should I be worried that there is no smoke, however, a smoky smell? Maybe it's just the smell of hot electronics since I passed the resistance and voltage tests with flying colors.
2. The replacement 6080 tube isn't "straight" what I mean is that the two towers inside are pointing to the left instead straight down towards the other tube (12AU7). I'll provide a pic, but everything is working and even music is playing. I made sure the pins were aligned correctly underneath the tube. It's just not symmetrical/
I'm about to install the speedball now and I have a feeling I'll face trouble in the process so I'll come back.
« Last Edit: January 27, 2015, 04:08:31 PM by TheCoolDoc »
I would suggest just enjoying the music for a while. I happen to love that "old electronics heating up" smell myself. Brings back a lot of fond memories of all the stuff I've played with over the years.
Offline TheCoolDoc
I went ahead and bit the bullet Doc. Before I proceed with the voltage tests I just need someone's word.
The tubes are lighting up properly except 2 LEDs on the PCB are giving problems. One is very dim and another isn't lit at all.
Pics below because I can't name the LEDs properly. The first two pics depict the ones with the issues. The other two pics are completely fine, but there for reference.
Offline TheCoolDoc
The LED on the large PCB board is definitely broken. It got separated from the wire itself and I can't fix that. The one on the "B" board, however, isn't working even after resoldering it.
Post voltages.
OK firstly I get to plug a new spare LED pack we sell:
http://bottlehead.com/product/hlmp-6000-leds/
This should be helpful to those who have trouble sourcing the HLMP-6000s when they need a replacement.
Secondly, on the side that has the unlit, unbroken LED, check the solder joints on the MJE350 and 2N2907 transistors.
Offline TheCoolDoc
I had to remove the right LED on the large main board. I tried resoldering what you asked Doc, but still no light on the "B" board left LED.
Since I've removed the LED, it's brother is much brighter as should be expected.
Is there no way to check voltages or even hear music without an LED? I thought all LEDs did were help troubleshoot. Since the LED itself was destroyed, I assume most things should be connected properly?
Also, PB said to post voltages, which I still haven't tested, but should I?
No, they are an integral part of the constant current source.  If you left one out and applied power to the board, the board is not going to work.  It's hard to say with great certainty, but you may end up needing to replace that entire board at this point.
Offline TheCoolDoc
I only applied power for 2 seconds. I've placed an order for the LEDs. The LED was broken regardless if I removed it or not, so the connection was broken in the previous test attempts.
How can I test the boards themselves? At this point I'm considering returning to stock and calling it a day as the speedball is tedious.
Replace the LED and run the board, that will be the most solid test.
Offline TheCoolDoc
I've replaced both LEDs, however, the one at the B board still doesn't light up. One is brighter than the rest on the main board. Pic below.
Should I run the voltage tests? I've turned the amp off. For clarification, all except left B are lit. Farthest left on big board is brighter than all.
Yes, the voltage tests will now be valid with all the parts having been installed in the amplifier.
Offline TheCoolDoc
Alright thanks. Here goes. FYI, LED is still not on after resoldering some stuff.
I'll be back.
Offline TheCoolDoc
Failure already. Got a huge spark at terminal 2. Terminal 1 gave me 125-130 V.
What to do? I've unplugged it.
Offline TheCoolDoc
Just noticed that the right LED on the left side of the main PCB takes a few seconds to light up and when this happens, its immediate left neighbor (which was immediately lit up) becomes brighter than the others. Takes maybe 5 seconds. All other ones turn on immediately.
