need troubleshooting help
aragorn723 · 11452
Offline aragorn723
Reply #30 on: January 31, 2015, 09:53:09 AM
gonna check later today.  I borrowed a capacitor checker too, so that will give another data point on whats up with those.
Dave
Offline aragorn723
Reply #31 on: January 31, 2015, 11:12:34 AM
Hi Paul,
These are the measurements with the pjccs outputs moved.
A2/A6     21.39v/21.4v
B2/B6     22.74v/22.74v
A5          1.697v
B5          1.712v
A3          0v
B3          0v
Dave
Offline aragorn723
Reply #32 on: January 31, 2015, 11:38:31 AM
Here are the capacitance measurements for the 150uf caps:
90uf
85uf
Is that normal to be that far off 150uf?
There are the measurements for the 220uf caps:
110uf
110uf
Dave
Reply #33 on: January 31, 2015, 04:41:35 PM
Well, the problem seems to have gone away.
Are you still hearing only one channel?
Offline aragorn723
Reply #34 on: February 01, 2015, 02:57:32 AM
I haven't tried hooking it back up yet, looks like it would be safe to do that now.  The one thing that I did besides disconnecting the PJCCS outputs was disconnect A6 (from one of the posts further up), and after realizing that was the wrong wire, re-soldered it (it comes from the terminal strip on the A side).  Maybe it was just a marginal solder joint.
Dave
Offline aragorn723
Reply #35 on: February 01, 2015, 07:19:01 AM
Hi,
Just tested the Quickie, and both sides work!  Guessing I should probably solder the pjccs wires back in (to their original locations).  What about the black gate caps, think i can put those back in too?  It definitely sounds better with them (there was a little bit of a grainy sound without having any caps in that location).
Dave
Reply #36 on: February 01, 2015, 07:51:52 AM
Dave,
Do that one step at a time.  Swap the PJCCS back first.  Then after verifying it works put the BG caps back.
Reply #37 on: February 01, 2015, 08:43:22 AM
The PJCCS does not care which side is which, but I would restore it just so that next time there's a question, you know the wiring matches the manual.
Yeah, put the caps back - making sure they are oriented correctly.
Offline aragorn723
Reply #38 on: February 01, 2015, 08:52:03 AM
Thanks everyone, its good to go  8)
« Last Edit: February 01, 2015, 03:50:52 PM by aragorn723 »
