feeench · 6652
The paint i used is a tire Rim paint.Thanks! Jamie I think your SEX have a choke installed near the front if you want to mount the XLR in front of the chassis like i did you need to make sure that the XLR will not interfere with those check the space carefully.i replaced the 22uf caps with SOLEN Poly those are large that is why i end up mounting the XLR lower than i would like to.
This is accomplished (in the cases where it is needed) on the impedance switch board.
